It is currently Mon May 04, 2026 11:18 am
 Post subject: Rebuild
PostPosted: Fri Feb 27, 2015 6:04 pm
I decided to do a thread on my rebuild since im doing so many frame changes and new parts. Here are my before pictures.
 Post subject: Re: Rebuild
PostPosted: Fri Feb 27, 2015 6:06 pm
Bare frame
PostPosted: Fri Feb 27, 2015 6:08 pm
Cut roof bars off
PostPosted: Fri Feb 27, 2015 6:11 pm
Bought some goodies!
PostPosted: Fri Feb 27, 2015 6:12 pm
Got my Webber 40
PostPosted: Fri Feb 27, 2015 7:07 pm
Made my mount for my cutters
PostPosted: Fri Feb 27, 2015 8:15 pm
If you go Water cooled later that cutter mount ought to be good for extra forward ballast. Stout mount dude
PostPosted: Fri Feb 27, 2015 8:51 pm
he aint going water cooled, he's allergic to anti-freeze 8)
PostPosted: Fri Feb 27, 2015 10:43 pm
PostPosted: Fri Feb 27, 2015 11:29 pm
Thanks red, and I couldn't go without that v dub sound!
PostPosted: Sat Feb 28, 2015 5:21 pm
Got my new heads!!
PostPosted: Sat Feb 28, 2015 6:30 pm
I want some!
PostPosted: Sun Mar 01, 2015 12:46 am
Got my motor put back together!! Soo shiny!!
PostPosted: Sun Mar 08, 2015 11:00 pm
Got my roof bars and front and rear pillar supports on, now to sand blast and paint!!
PostPosted: Tue Mar 10, 2015 11:41 am
If this buggy was used in the mud, I would suggest checking the thickness of the tubing walls while you are reconditioning.
I recently found weak tubing walls that rusted from the inside-out.
1) Flip the buggy onto it's side.
2) Using a welder's slag hammer, tap around all of the lower tubing that was facing the ground horizontally. This is where water collects inside of the tubing.
3) Water also collects in the two vertical tubes that connect to the rear main torsion housing. All offroad frames eventually fail where
the frame members connects to the rear torsion housing (from rot).
PostPosted: Wed Mar 11, 2015 12:16 am
That buggy has never been in mud :mrgreen:
PostPosted: Wed Mar 18, 2015 9:21 pm
Painted it dark shadow grey! Now its assembly time!! Hopefully itl be done this weekend so I can hit some trails!!!
PostPosted: Sun Mar 22, 2015 8:24 am
Got everything done but the brake lines ran, doing that today, started it up with the new heads and carb and it screamed like a raped ape! But for some unknown reason the rear seal is leaking oil bad so I have to figure that out. Here are a few pics
PostPosted: Sun Mar 22, 2015 8:30 am
[attachmenit=1]1427027435718.jpg[/attachment]
PostPosted: Fri Mar 27, 2015 7:00 pm
Got to do my first cutter donut today..... it was amazing!!!! The only thing I have left to do is mount the harnesses, paint the rims and move the headlights down, then go get the carb tuned! Hope to hit the woods next weekend!!!:mrgreen:
PostPosted: Fri Mar 27, 2015 7:30 pm
That's a nice looking buggy
Just that guy
PostPosted: Fri Mar 27, 2015 9:29 pm
Good job.
PostPosted: Sat Apr 04, 2015 11:41 pm
Test ride went awsome today! I love having the cutters and hydraulic clutch! and its got so much more power and throttle response with the new carb and heads!!
