It is currently Mon May 04, 2026 7:25 am
Post new topic Reply to topic  [ 310 posts ]  Go to page Previous  1 ... 7, 8, 9, 10, 11, 12, 13  Next
PostPosted: Sat Dec 06, 2014 12:13 am
frankenbuggy06 wrote:
Realistically you need a roller with a 6 rib and a adapter plate (500) wiring harness and computer 400 and a motor
Alright thank! Il prob bring my frame to my buggy shop and get the torsion well placed and just tac welded because he told me it really has to be perfect.
Cush53 wrote:
TheOriginalOne wrote:
Cush53 wrote:
No the adapter come with adapter plate and flywheel. Pressure plate and clutch separate I run a stage 2 Kennedy pressure plate with my six rib and eco
Alright so the clutch and pressure plate is together? Thanks! Il start ordering parts when i come back from vacation in 1 week :)
Sent from my Nexus 5 using Tapatalk
No clutch disc and pressure plate are usually separate to
Alright i dont know alot abou those!
Thanks!
PostPosted: Sat Dec 06, 2014 5:07 pm
I made a list, do i have everything? and if you want, help me with the prices of each, i will do some research for the prices.
Dune buggy parts list
Front End
-axle beam
-spindles x2
-arms x4
-shocks x2
-brakes x2
-brake line x2
-wheels x2
-steering/rack&pinion
-tie rods
-battery
Middle
-pedal assembly
-thottle pedal/electronic ecotec
-stleering rod
-steering wheel
-quick release adapter steering wheel
-steering wheel holder/bearing
-racing seat
-5 point harness
-shifter/parking brake
-cutting brakes
-brake line for cutting brakes x2
Back end
-gaz tank
-6 rib
-pressure plate kennedy stage 2
-clutch stage 2 kennedy
-eco tec 2.2L
-fuel pump
-fuel filter
-eco tec adapter plate
-air filter
-radiator
-radiator hoses/clamps
-3x3 trailing arms x2
-bearings for trailing arms x2
-torsion bar x2
-brakes x2
-brake line x2
-torsion tube
-930 cv axle kit
-shocks x2
-tires x2
Wiring
-voltage guage
-rpm gauge
-temp guage
-speed guage
-switches x5
-fan switch
-front LED bar switch
-back LED bar switch
-ingnition ON switch
-push button start
-light bar front
-small light bar rear
-ecu/computer for eco tec
Fabrication&miscellaneous
-metals 200$
-nuts and bolts 50$
PostPosted: Sat Dec 06, 2014 5:21 pm
looks like a $10,000 list to me....been there, done that.
PostPosted: Sat Dec 06, 2014 5:25 pm
Yeah its a pretty long list, im just not sure if il get 10k worth of fun, since i already have a dirtbike. i can start building it slowly by slowly.
PostPosted: Sat Dec 06, 2014 5:53 pm
worth every penny...ive had dirt bikes,quads,toyotas,k5s,jeep cj and my buggy is defenetly my favorite
PostPosted: Sat Dec 06, 2014 5:59 pm
Same here. Had all kinds. Nothing like a buggy.
PostPosted: Sat Dec 06, 2014 6:21 pm
A few more things to add on...
If you use stainless steel - Nuts and Bots will be more like $400 - $500
Front Tires
Front Beam Bushings
Tie Rod Ends
Link Pins
Front Torsion Bars
Seats
Shifter Box
Shifter Rod
Shift coupler
Trottle Cable
Hydraulic clutch
Paint & Powder Coat
Steering Shaft
Spring Plates
Sprint Plate Caps
Spring Plate Bushing
Battery Cables
930 Stub Axles
930 Drive Flanges
Transmission Mount Kit
Hi Torque Starter
Fly Wheel
Radiator Fans
Radiator Thermostat Switch
ECU Harness
Wire/Connectors
Fuse Box
Air Filter and Air Filter Box
Headers
Exhaust
Spark Arrester
PostPosted: Sat Dec 06, 2014 6:42 pm
Wow guys. You make me have more respect for my rig. It's hard to believe we have that much in a tubed vehicle.......I love it!
PostPosted: Sat Dec 06, 2014 6:58 pm
This list does not even count the important things...
Cup Holders
Radio
Speakers
MP3 Connectors
GPS
CB
Air Horn
Fire flame graphics
PostPosted: Sat Dec 06, 2014 7:02 pm
Cup Holders
Radio
Speakers
MP3 Connectors
GPS
CB
Air Horn
Fire flame graphics
Forgot the most important thing, having some pu$$y in the passenger seat ;)
"Just pin it ! she'll go!"
PostPosted: Sat Dec 06, 2014 7:11 pm
I'll sell u mine and save u a lot of time and money.
PostPosted: Sat Dec 06, 2014 7:25 pm
I remember trying to make my list.... I had everything on my list and about 50 other things that were not on it sitting on the table at Gary Davis's shop and i still had to go back multiple times for things I forgot. I have about 4500 in my buggy and its just got drums with no cutters and a stock pedal assembly. I am dropping about another 700 on it this winter for breaks tubing and a carb. But no matter how much money I put in it I dont regret it because I love my buggy. Its an addiction. Good luck on your build, youl love it.
PostPosted: Sat Dec 06, 2014 7:38 pm
Is that offer for anyone?
PostPosted: Sat Dec 06, 2014 7:53 pm
I'll let her go to anyone with cash
PostPosted: Sat Dec 06, 2014 8:02 pm
Oh and you will need a side shift tranny if ur doing a single seater , or build special linkage
PostPosted: Sat Dec 06, 2014 8:44 pm
Are you gonna build another one
PostPosted: Sat Dec 06, 2014 9:13 pm
Wow thanks guys, really motivating me! your asking 9500$ for that buggy right?
i think ill just take me time and build it and learn the whole process of it at the same time! the list is long. im in florida right now in vacation and i found a guy with nice parts like 3x3 arms and full front end. i might buy it and get it shipped to my house!
really appreciate guys i promise you will see this buggy running in 2015 summer!
PostPosted: Sat Dec 06, 2014 9:30 pm
The more money u throw at it the faster it goes lol
PostPosted: Sat Dec 06, 2014 9:35 pm
yeah $$ makes everything faster ahah
here is the link http://lakeland.craigslist.org/pts/4729439235.html
i think everything i like except the back tires i can get them here for cheaper and i rather firestone tires!
how much do you think is a good deal for all that
-3x3 arms,spindles,axle beam,fox shocks,rack&pinion,front trailing arms, and tranny which is unknown at this point what type of rib!
thanks
PostPosted: Sat Dec 06, 2014 9:56 pm
I got a few ball joint beams laying around if u wanna drive by I'll give one to ya. Complete from drum to drum and some stock rear arms to get u Rollin
PostPosted: Sat Dec 06, 2014 10:14 pm
Thank you very much, but you are just very to far away from me.(im in montreal,canada,quebec) and my frame is made for link pin.
but thanks!
PostPosted: Sat Dec 06, 2014 10:17 pm
trailing arms 3x3 500
front axle beam 200
front trailing arms 500
front spindles 375
rack and pinion 175
the fox shocks front x2 250
this is what the guy wants for his pieces, i find it expensive but i dont know the prices that these items sell for, he also has a 6 rib side shift 094. i could go see them then get them hauled!
tell me what you guys think.
Thanks!! :)
PostPosted: Sat Dec 06, 2014 11:22 pm
You may need a side by side and just ride. I think you will be burnt out on your build, it takes a lot of time, money and patience on a buggy build. And there is no limit on expense
PostPosted: Sat Dec 06, 2014 11:25 pm
Yup
PostPosted: Sat Dec 06, 2014 11:39 pm
No disrespect , by no means.
