It is currently Sun May 03, 2026 5:39 pm
Post new topic Reply to topic  [ 85 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Thu Nov 27, 2014 9:20 pm
Ok. So they are regular bearings. I thought they were different. I should know if I my my money next week from my ex employer;)
PostPosted: Thu Nov 27, 2014 10:56 pm
One double row bearing on the inside, same diameter as stock only twice as wide and it's sealed. Then two stock bearings on the out side. The housing still uses both inner and outer stock seals, only difference is the center spacer is shorter on the new housings.
That is why I NEED the center spacers. So if you have a bunch of them PM me, I'll buy them.
PostPosted: Thu Nov 27, 2014 11:18 pm
If I had spacers you could have them, but sorry, I don't have any.
PostPosted: Fri Nov 28, 2014 6:30 pm
I guess there will be a pair left when I'm done you can have
PostPosted: Mon Dec 01, 2014 6:28 pm
BigDsmith, are you ready??
PostPosted: Mon Dec 01, 2014 6:52 pm
Lol... Looks good Mike. Still waiting on my check.
PostPosted: Sat Dec 13, 2014 4:29 pm
Give you an idea on the differences in arm lengths.
The top is obviously stock, center is a 3X3, bottom is a 3X5
PostPosted: Sat Dec 13, 2014 5:18 pm
Dadgone those look good. Maybe today is the day.;)
PostPosted: Mon Dec 15, 2014 8:21 pm
I hope mine look that great oh they do
PostPosted: Mon Dec 15, 2014 9:13 pm
Uuuugh......lol
PostPosted: Mon Dec 15, 2014 10:17 pm
Hey RD-Glider I hope those new Mad Mike arms are driver proof! :D
PostPosted: Mon Dec 15, 2014 10:21 pm
Guaranteed to be
PostPosted: Thu Jan 08, 2015 10:05 pm
Bump
PostPosted: Fri Jan 09, 2015 8:38 am
The bottom appear to be 5x3 (five wide and three back)...None the less, top notch work!!
PostPosted: Mon Jan 12, 2015 4:47 pm
MadMike wrote:
The arms do not come with bearings or seals. I can provide them at an additional cost.
As far as what material I used, right after you buy a set, I'll let you drill a hole into them to find out.
Now, how thick do YOU think they are to survive this, not once, not twice........
https://www.youtube.com/watch?v=gYIXHrH ... ata_player
lol thats a heck of a way to advertise.. lool love the vid, hope he was ok.
PostPosted: Mon Feb 23, 2015 10:29 pm
I got my arms from Mike tonight. Absolutely awesome craftsmanship and quality.
PostPosted: Fri Feb 27, 2015 11:52 pm
Do you make arms that are 3in wider by 5in longer?
Shine is fine, but flats where its at
PostPosted: Sun Mar 01, 2015 9:21 am
look 11 post up it tells the tell.and yes he makes 3x5 he can make anything you want :wink:
PostPosted: Sun Mar 01, 2015 1:05 pm
Do you build those in micro stub versions ?
PostPosted: Sun Mar 01, 2015 2:22 pm
Sorry for not answering sooner, messed my back up earlier in the week, sorta been out of it since.
Yes I make 3X5 arms.
No micro stub arms. If you want micro stub arms you'll need to talk to Todd at Precision Alloy 360-887-2000
or Nick aka buggybarn here on the board.
PostPosted: Fri Apr 17, 2015 7:24 am
EMPI part number 16-2400
http://www.amazon.com/EMPI-16-2400-Chro ... B00FF9AYNY
PostPosted: Thu Apr 23, 2015 2:00 pm
I am building front arms and there will be a extra set available. They can be 4 X 1's or 2.5 X 1's, torsion or non-torsion.
I have a set of neutral combo spindles ready to go. $500 +shipping
I have enough material to build two +6" super beams, no torsions $300+ shipping
In the coming weeks I'll be back to building rear arms, order yours now.
Affective immediately all shipments will be made through either FedEx or UPS. The Postal Service has lost two of my last shipments and I refuse to support their incompetence.
I apologize for any inconvenience this may create.
PostPosted: Sat Apr 25, 2015 4:52 am
I will need a price on:
1 super beam (ball joint spacing).
1 pair of the longer front arms.
1 pair of 3x3 rear arms.
I bought a new frame with the ball joint
spacing, but I can change it to link pin
spacing easily. Please opine.
PostPosted: Sat Apr 25, 2015 11:42 am
No going to be able to do a ball joint beam because of the two different size tubes used to make the stock ball joint beam. If you were to reconfigure the chassis to link pin, then it will work out.
Give me a call Jim, it's been a while since we talked last.
724-650-0816
PostPosted: Fri May 15, 2015 9:26 am
Hello,
Do you make raised 3" king pin stub axels? also, do you have rear arms with bearings that fit 930 or 934's housings for short stub axels?
