It is currently Mon May 04, 2026 10:20 am
Post new topic Reply to topic  [ 31 posts ]  Go to page 1, 2  Next
PostPosted: Tue Nov 25, 2014 8:45 am
Looking for 1985-up VW
water-cooled syncro 4WD
transmission.
Unusable cores considered!
(place-holder for fabrication).
Jim in Pittsburgh,Pa.
jimp007at Verizonnet
PostPosted: Tue Nov 25, 2014 10:03 am
Good Luck with the search.. They are really hard to find. You might want to try Samba as well.
Just wondering, what are you going to do with it? Is if for a van or a project?
PostPosted: Tue Nov 25, 2014 10:37 am
I am designing accessories for all buggy applications.
I need a syncro transmission so that I can produce
a CAD model as well as test out my products.
I will be starting a new thread on this website soon.
Do you have a syncro 094 unit to sell or donate?
Can we move the Q&A to a new thread and leave
this thread open to offers?
PostPosted: Tue Nov 25, 2014 12:06 pm
How much you paying? I have, repairable [needs 3/4 hub] or one with hole in gear carrier. Also one good but model without locker.
PostPosted: Tue Nov 25, 2014 12:26 pm
PM sent.
PostPosted: Tue Nov 25, 2014 1:27 pm
Is this Pittsburgh Jim??
PostPosted: Tue Nov 25, 2014 2:09 pm
The same. Have you got a syncro transmission(s) for me?
I am back into this crazy hobby once again.
I started an offroad 4wd buggy thread (transmissions)and
I will be documenting a new build with alot of pictures.
(hopefully).
See ya in the spring @ Wellsville.
PostPosted: Tue Nov 25, 2014 9:06 pm
Sorry I don't, I'll keep an eye out. Maybe Mickey Mouse can get you your old handle back.
PostPosted: Tue Nov 25, 2014 9:47 pm
I know where there is some. Rt14/480. And rt 80 split
PostPosted: Tue Nov 25, 2014 10:32 pm
I called them about their Vanagons a while
back. They said that they only have 2WD.
Thanks!
PostPosted: Tue Nov 25, 2014 11:24 pm
Jim, might also want to consider Subaru. There is a reversed 4:86 ring and pinion available. I know this build I'm doing now is the last I'll do with a VW trans.
PostPosted: Wed Nov 26, 2014 1:05 am
I am with you Mike... When I blow up my 6rib, I will most likely go to a Subaru. Although, I have not see a lot of off road examples and I am a little worried since the R&P is so small.
 Post subject: Re: Hyd. Slave cylinder
PostPosted: Wed Nov 26, 2014 3:04 am
Are you talking about foreign auto in Streetsboro oh, if so that guy is crazy on his prices,wants like 550 for a three rib
PostPosted: Wed Nov 26, 2014 11:23 am
Stock Subie will handle 280hp a properly prepared box will handle 650hp according to these guys.
http://www.subarugears.com/
PostPosted: Wed Nov 26, 2014 6:44 pm
When I spoke with them last year, they were a little concerned about running 35 inch tires. Now that they have the 4.86 gears, the suby trans should be fine with 35 inch tires.
PostPosted: Wed Nov 26, 2014 7:42 pm
Holy shizknit that's expensive? With shipping you could buy Passat the entire pull a part
PostPosted: Wed Nov 26, 2014 10:28 pm
They are a little pricey.. For comparison, what does it cost to buy all Weddle gears, a german super diff and have the trans rebuilt?
PostPosted: Thu Nov 27, 2014 1:10 pm
Buy a mendeola at least there is the you break it they replace it once. I can't imagine the shipping from Australia
PostPosted: Thu Nov 27, 2014 1:19 pm
Shipping is ridiculous. I got a set of wheel adapters from China a few years ago for $11 apiece. Custom made. Customs held ransom on them for $90. Between shipping and customs, I lost my tail.
PostPosted: Thu Nov 27, 2014 1:50 pm
Still cheaper to use a Subie that I would build myself. $2,000 plus the cost of a 5 speed trans verses $6500 for an entry level MD4E Mendeola.
At that rate I could scatter 2 Subie set ups and still not have the same coin as a Mendeola.
I know the next question is which is stronger. I have no idea but I do know this, a stock Subie trans is designed to hold up to 280hp. A stock VW box was designed to stand up to what, 100hp max?
http://ranchotransaxles.com/mendeola-transaxles.html
Sorry for the hijack Jim, we got carried away here.
PostPosted: Thu Nov 27, 2014 7:02 pm
Mike I knew you would chime in on this one. I think the Subie trans built domestically could be the answer, but I don't want to be the guy experimenting. I did that with VW trans building got a lot of practice pulling the buggy apart and talking dirty
PostPosted: Thu Nov 27, 2014 7:32 pm
I may be that guy thinking of making a new buggy. Just know looking into it. Anyone knows if I can put my ecotec on one or will I need to stay with a subie?
PostPosted: Thu Nov 27, 2014 7:51 pm
Subaru gears already has an American distributor down south somewhere. I have looked into them as well. That saves on the shipping hassle. The last time I was on their site they only advertised a 4.4:1 r&p. 4.86 would be nice.
PostPosted: Thu Nov 27, 2014 7:54 pm
I only ever see synchro transmissions on ebay for huge $$$... and Colorado... but they were all still in vans driving around. Must have seen 15 synchro vans in a week out there...
PostPosted: Thu Nov 27, 2014 8:21 pm
They now have a 4.86 R&P, that's the main reason running a Subie trans becomes doable for what we do. If they have a US distributor, it's a real closely guarded national secret. If they had one, I doubt they would list shipping to the US.
