It is currently Tue May 05, 2026 2:33 am
Post new topic Reply to topic  [ 310 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 13  Next
PostPosted: Thu Nov 13, 2014 11:02 pm
Do yall not have any junk yards ? Also bus trannys are hard to come by. I think you will find an 1850 vw is faster than it sounds, them vws are running little motors
PostPosted: Fri Nov 14, 2014 10:55 am
bigDsmith wrote:
If you don't have a decent amount of skill fabricating and knowledge on how and what to build, it can be easy to get burned out on trying to build one. It may be better to buy one running. Then as you see and read what other people have or are doing, you can upgrade while enjoying your riding. Upgrading never ends.....there is always new ideas and products.
ok thanks guys, would this be a good choice compared to the previous one the red 1835cc.?
2387 stroker with dry sump oil system, it has 044 super flow heads 1.25 ratio rockers all cb performance internals has a mad 6al box with built in rev limiter. Has almost new cut boggers on the back 33/14.5 on duralite aluminum bead locks. Has 3x5 trailing arms with torsion eliminators. Have fox 2.0 air shocks on the back. Single handle cutter brake, wilwood clutch an brake pedals an master cylinders. Aluminum wheels an homeplates on the front
thanks sorry for all the posts :wink:
PostPosted: Fri Nov 14, 2014 11:17 am
I don't think those are super flows unless the got the conversion covers. And 044 are a different head anyways
PostPosted: Fri Nov 14, 2014 11:41 am
I can't see the pics in large on this app for some reason .. but if it has that stuff it sounds like not a bad deal , I would be careful getting a sooped up car , I know I know !!!!!! Everyone wants a bad ass fast buggy(including me) .. but with big hp the reliability goes right out the window plus every time it does brake it cost $$$$$$$ to fix it .
Food for thought.
PostPosted: Fri Nov 14, 2014 12:23 pm
Food for thought.
i was thinking about the same thing, between this one 2387 stroker and the 1835cc is there a big difference in power and reliability? i will doing trails, hill climbs and mudding :)
PostPosted: Fri Nov 14, 2014 12:53 pm
Honestly I don't know a lot about vws but I do know I have 2.3 ford aspirated and it's pretty fast , but again it depends on buggy weight. I had a friend who had 1600 dual port on a 1000lb buggy and it was pretty quick ! Faster than my 2000lb 2.3 buggy
PostPosted: Fri Nov 14, 2014 1:58 pm
TheOriginalOne wrote:
Food for thought.
I started with a 1835, now i have a 2387 and there is a HUGE DIFFERENCE...its very reliable i beat on it pretty hard..
PostPosted: Fri Nov 14, 2014 1:59 pm
ok yes i figure weight is important.
is it possible to make these buggies with more ride height like 2-3 feet or more ground clearance?
thanks
PostPosted: Fri Nov 14, 2014 4:13 pm
Anything is possible , but I would not go high!!! It will fudge up the center of gravity and then u will have a jeep lol I like 12 to 16 in of suspension travel with 33s on the rear and 30s on the front , if u Wana do 3 ft of clearance I'd go get a rock crawler
PostPosted: Fri Nov 14, 2014 4:44 pm
I wouldn't go to big on the tires expecially if you are going to run it hardcore, it will cause extra wear and tear on the tranny, cv,s, trailing arms, ect,...
PostPosted: Fri Nov 14, 2014 5:08 pm
alright i got another question for you guys :)
i found this only 1:30 hr away from my house.
http://www.kijiji.ca/v-achat-et-vente-d ... nFlag=true
do you think there is potential? i can remove the engine and sell it and put a bigger one and add some metal tubing under and around the engine for protection?
i really like this one Image
but its gonna cost 1000$ for gaz since hes 20hrs away! :shock:
Last edited by TheOriginalOne on Fri Nov 14, 2014 5:15 pm, edited 1 time in total.
PostPosted: Fri Nov 14, 2014 5:12 pm
Not trying to be mean but I wouldn't touch it with a 10 ft pole, to much work not many good parts, the 2 other buggys u are looking at are 4 times better
PostPosted: Fri Nov 14, 2014 5:17 pm
alright thanks. i really dont know much but im learning!
PostPosted: Fri Nov 14, 2014 5:20 pm
I would guess you could get it shipped for half that.
PostPosted: Fri Nov 14, 2014 6:05 pm
I completely agree. The frame needs to entire rear cage, the trans looks like a swing axle so the trans and torsion housing will need to be replaced. The engine is too small. There is not much to that buggy that you would not touch.
PostPosted: Fri Nov 14, 2014 6:11 pm
thanks for the answers guys and yea i will look into that
PostPosted: Fri Nov 14, 2014 6:23 pm
This is when we had it
PostPosted: Fri Nov 14, 2014 6:27 pm
I would fly down and look at it then have it shipped , may cost the same but I hate buying it with out driving it
PostPosted: Fri Nov 14, 2014 6:38 pm
If it makes u feel any better I drove 15 hr to get my buggy
PostPosted: Fri Nov 14, 2014 6:55 pm
Thanks! i actually googled your username and found pictures of it.
it a really nice buggy i like the look of it!
and yea it would be best if i actually it its a 40hr round trip which is not small hahah my father has people he knows that are truckers so i might get a good deal to get it hauled.
PostPosted: Fri Nov 14, 2014 6:58 pm
Just take ur dad or friend and make a trip out of it go sight seeing and have fun
PostPosted: Fri Nov 14, 2014 7:10 pm
yea its just because my budget is tight, for round trip 4000km total with my dads truck which is a v8 does about 14liter/100km on highway with light pulling so thats around 700$ plus trailer rental since i dont have one, so i will make my decision for what buggy and then make my plans and will drive there with a friend or my father hopefully he pays the gaz ;) hahaha or i will trust the seller and get this bad ass buggy shipped right to my door :)
-- or can i take a mini car trailer that just the front wheels go on the trailer? or this is a bad idea?
what engine was in that buggy before you sold it Nribuggys and it was in good condition i guess?
PostPosted: Fri Nov 14, 2014 7:25 pm
I wouldn't put it on a car dolly !! If it jumps in gear engine will burn up , plus it will eat up the rear tires ,
PostPosted: Fri Nov 14, 2014 7:26 pm
I would buy a good one even if it cost more , you get what you pay for
PostPosted: Fri Nov 14, 2014 7:45 pm
alright i will look on craiglist
cron
