It is currently Sun May 03, 2026 3:29 pm
 Post subject: What carb is best?
PostPosted: Fri Oct 17, 2014 10:16 pm
I have a 1776 and im running a solex right now and its just not enough carb for it. I was wondering what carb would be best for it. I have been told a progressive would work but other guys say those aren't really big enough either. Any suggestions??
 Post subject: Re: What carb is best?
PostPosted: Fri Oct 17, 2014 10:47 pm
I have a weber 40 on mine brandon. It runs great. Same motor, but duals would wake it up!! Only 2hundred more!!
PostPosted: Fri Oct 17, 2014 10:54 pm
Yours sounds healthy for sure, whats a price tag on a 40? Ill have to buy intake and all.
PostPosted: Sat Oct 18, 2014 12:01 am
I think it was 350. For intake and all. But your gonna want to change the throttle linkage and add jet doctors at least
PostPosted: Sat Oct 18, 2014 12:10 am
put a 36 on it ! you will drown your motor and wash the oil out of your rings. un burnt gas dilutes your oil. I love young guys that are here to pass on the tradition.
PostPosted: Sat Oct 18, 2014 12:34 am
Go with a single del or webber 40and don't look back everything else is junk
PostPosted: Sat Oct 18, 2014 12:35 am
Dont listen to that guy
:idea:
PostPosted: Sat Oct 18, 2014 12:55 am
The solex guy!!
PostPosted: Sat Oct 18, 2014 8:21 pm
Looked one up online, its 319 for a Weber 40 kit with intake and all. Looks l like my next upgrade!!! :D
PostPosted: Sat Oct 18, 2014 9:49 pm
I'll drop it past this point. A 36 will be best for your 1776. You will be happy with a 40 but a 36 will be ideal. You will thank me later if you do. I ran a 36 on my 2024 all thru the 90's at Chilton county and it ruled. It had excellent top end, killer bottom end and instant recovery. Zero bog.
PostPosted: Sun Oct 19, 2014 10:18 am
go with a single or dual 40s....if you jet n tune right you wont have any problems...and you already have the good stuff if you want to go bigger on motor
PostPosted: Sun Oct 19, 2014 9:34 pm
A 40 will work fine if you change the chokes in it to make it smaller. Basically you will install smaller venturis in it. This will size the thing for your smaller displacement engine and make it respond correctly. Dual 40's would be much better than a single if you can afford it.
PostPosted: Sun Oct 19, 2014 9:40 pm
you can make about any carb work with the correct jetting and tuning, single or dual. Another key thing to watch is venturi size. Too big and bottom end response will suffer, too small and it will overfuel at high rpm and either way you cannot jet it properly. I used to run a 1776 with dual 34 ICT's that ran great. Generally the more carb you put on the more difficult it will be to get good bottom end response. Too much is as bad or worse that too small. Best bet is to do what you are doing here, see what other guys are running with your engine size, cam, etc. Good Luck, lots of options out there.
