It is currently Mon May 04, 2026 4:58 pm
 Post subject: 2500 cam choice
PostPosted: Thu Sep 25, 2014 9:38 pm
Building 2500 for my 1 seater decided on everything except what cam to run buggy will be in the low 1300s with 246 second gear stones and all the basics super flow heads lightend crank 1.4 rockers any other information needed let me know so what cam do we like around here for this setup
 Post subject: Re: 2500 cam choice
PostPosted: Thu Sep 25, 2014 11:33 pm
A potato cam, they sound cool...potato, potato, potato or a wooden cam.. rev it and it goes wooden wooden.. wooden wooden
LEGALIZE BLUEGRASS!!!
Save a tree... eat a Beaver
PostPosted: Thu Sep 25, 2014 11:34 pm
How much and where :shock:
PostPosted: Fri Sep 26, 2014 12:35 am
If your gonna buy a off the shelf cam fk-43 with 1.4 rockers i ran one in mine for a while it worked real good ..Or call drews ask Brain about there hill climbing cam ..it works too
PostPosted: Fri Sep 26, 2014 8:22 pm
Drews 909 hill climber cam. I have dyno this cam at 200 fp Tq at 3900rpm with Drews ported S/E heads . You can call me Kevin Hyde at 812 584 7644
PostPosted: Tue Sep 30, 2014 9:36 pm
The 909 cam needs Large cc eng.1.4 rockers and ported heads like drews ported S/E or S/F dual valve springs 44 or 45 carbs. The 909 has more topend power then a FK42 or 110 and more lowend power then a FK43 or 120 . I did most of the Dyno testing and runing the engs. in a buggy . The 909 drives good and makes good power . PS Drews has sold a lot of this 909 cams. But I cant tell you who has them :twisted:
PostPosted: Wed Oct 01, 2014 7:09 am
Lol well I'm thinking about trying it I want something with some top end but don't wanna loose my bottom either I will give you a call about it this weekend
PostPosted: Wed Oct 01, 2014 11:30 pm
One of the guys I ride with runs drews cam in his ss 2500 and I must say it is very impressive. He told me it will melt his firestones on the blacktop by just "puttin' 'er to the wood".
You gotta wind it up like a rubber band!!
What's that? That there is a meddler catcher, and you're the one it caught.....
PostPosted: Mon Oct 06, 2014 4:49 pm
Well called drews to get some questions answered on the cam I cam across a deal on some 1.5 rollers and the guy I talked to at drews said they woukd not go over 1.25 on that cam
PostPosted: Mon Oct 06, 2014 7:45 pm
Call me or talk to Brain Drew we are the only two people that no what the specs are of cam . The guy are not told much about the 909 cam . And they do run some of the small engs 2332 with 1.25 . I run some old scat and they do 1.45 but you have to have good springs .
PostPosted: Mon Oct 06, 2014 7:46 pm
Call me or talk to Brain Drew we are the only two people that no what the specs are of the cam . The guys are not told much about the 909 cam . And they do run some of the small engs 2332 with 1.25 . I run some old scat and they do 1.45 but you have to have good springs .
PostPosted: Mon Oct 06, 2014 7:48 pm
Can you text I'm at work if not will call tomorrow
PostPosted: Mon Oct 06, 2014 9:06 pm
When we were building my 2500 we called and asked...
Will it work on 1.4... Don't know
Will it work with k800 springs... Don't know
How much seat pressure u need... Don't know
What lifters would u run with it... Don't know
Needless to say I ain't running nothing in my motor y'all ain't giving any info about. Maybe the guy didn't know. Maybe it's top secret.
PostPosted: Tue Oct 07, 2014 8:01 pm
call brothers vw in california. they build monsters all the way up to 2866 ! they are a very well known reputable shop out west. parts,machine work, complete motors, etc.
PostPosted: Thu Oct 09, 2014 11:49 pm
I used a 1.4 with no problem
PostPosted: Fri Oct 10, 2014 8:11 pm
Will it work on 1.4... Don't know - Yes
Will it work with k800 springs... Don't know - Yes
How much seat pressure u need... Don't know - 135 to 150
What lifters would u run with it... Don't know - Scat lube-a-lobe - No lightweights
PostPosted: Fri Oct 10, 2014 11:24 pm
I am not an engine builder, and I am probably not the sharpest knife in the drawer but I think that cam,heads, powerband and compression ratio should all be taken into account before starting an engine build. Also Gary Davis at Davis Motorsports has been a huge help, providing knowledge and parts.
Good Luck
Kenric
PostPosted: Tue Oct 14, 2014 8:40 pm
X2 kvw . You have to look at all of it. Buggy weight .gearing tire size. eng.size. carbs .comp. heads .valve size. rockers. rod stroke ratio. R.P.M . Fuel otane. And where you ride.
PostPosted: Wed Oct 15, 2014 11:09 pm
X3 ...on that
PostPosted: Tue Oct 28, 2014 8:22 pm
Drews off road 909 cams are in . This is what i am running Drews Ported S/E heads 1.4 rockers bug pack 4046 dual springs titanium retainers scat lube a lobe lifter 'Not lightweight hollow wons" .053 chromoly pushrods 10.3to1 comp. dual 44 carbs with 6" stacks . Peck TQ 3900 rpm . You can see it run at dynoing ky 1600
PostPosted: Wed Oct 29, 2014 10:53 pm
I ran the cam with Cb-ultra wedge port heads 1.4 rockers 88crank ,95 pistons ton of bottom end and plenty of power up stairs too..I would recommend it to any body
PostPosted: Mon Nov 16, 2015 9:27 pm
Kevin, is there a good time I can contact you to talk some more about this camshaft? I can call or text. Thanks, jeff
PostPosted: Tue Nov 17, 2015 8:06 pm
Sorry not on here much you can give Call after 5pm . Thanks
