It is currently Mon May 04, 2026 3:30 am
PostPosted: Mon Sep 01, 2014 5:06 pm
Stand alone harness all excess wiring trimmed out. All unnecessary emission and transmission codes deleted and most important vehicle theft deterrent system disabled. Harness comes labeled with a 5 wire hook up. Both cooling fan and fuel pump relays already wired in. Also check engine light. This will fit the earlier ecotecs the ones that have a cable operated throttle body. And a single coil pack on valve cover.330 442 5166. $350
PostPosted: Mon Sep 01, 2014 10:22 pm
No issues with mine and super easy installation thanks again jeromy
PostPosted: Sat Sep 06, 2014 9:02 am
No problem Cush. I will headed to rush for the weekend can bring this with me if anyone is interested
PostPosted: Sat Sep 06, 2014 9:12 pm
do you make them up or are you just have this one for sale thank's
PostPosted: Sun Sep 07, 2014 7:36 am
I use a stock harness and trim all the extra stuff you don't need. Then I wire in the relays in so the ECM controls them like in the car. Then I flash the ECM with hp tunners. I have done these harnesses and sold them on woodsbuggy , the samba and eBay with no issues.
PostPosted: Sun Sep 07, 2014 9:13 pm
do you do the newer ecotec motor,i have a 06 chevy can you do the harness for that one and how much thank's
PostPosted: Sun Sep 07, 2014 9:47 pm
If it's a 2.2 you can run it just need to change the TB to cable from wire drive. That's what I done works great.
PostPosted: Mon Sep 08, 2014 7:48 pm
I can do the 06 give me a call and I can find out what exactly you are looking for.
