It is currently Sun May 03, 2026 8:46 pm
PostPosted: Mon Aug 18, 2014 7:17 am
I took my Weber 40 IDF off my 1600DP because I could never get it to run good! Always cleaning out the idle jets and it was running real rich. I switched back over to the stock carb and also have a 009 dizzy with compufire ignition. any secrets to making it good offroad? So far It runs great, but havent really pushed it offroad yet.
Any tips would be great :D
PostPosted: Mon Aug 18, 2014 9:17 am
Run a 4" rubber hose to extend that brass spill over tube inside the top of it. And take the gold looking anti dieseling gadget off the side and clip the copper rod off. When it goes bad it won't idle. Oil your butterfly bushings b4 every ride. When they wear they make bad intake leaks. And do not run the old oil bath air cleaner off road. Use 1 of those washable KnN filters.
PostPosted: Mon Aug 18, 2014 11:19 am
I did make a vent tube for the overflow for the bowl , as for air cleaner this is exactly what im running with a foam filter.
I'm not sure what you are talking about with the anti diesel gadget though. LOL
PostPosted: Mon Aug 18, 2014 11:46 am
He is talking about the gold looking tube on the side. should have a wire going to it.
PostPosted: Mon Aug 18, 2014 12:47 pm
this has the rod in it? the thing that says solex
PostPosted: Mon Aug 18, 2014 1:35 pm
That looks like the electric choke coil don't think that's what he is talking about
PostPosted: Mon Aug 18, 2014 2:01 pm
thats what I thought that was..
BTW I will probably be by the your store in the next couple days to pick up a adapter so I can hookup my front brake lines
PostPosted: Mon Aug 18, 2014 3:29 pm
Other sideImage
Round thing on bottom someone may have taking it off. It was for lead fuel.
PostPosted: Mon Aug 18, 2014 4:24 pm
bluebuggy wrote:
Other sideImage
mine still has that round plug that electrical goes into. so can i just unhook the electrical wire on it and call it a day?
PostPosted: Mon Aug 18, 2014 6:31 pm
No have to pull it out. There is a small moving end on it. cut that off then put it back. Then your good.
PostPosted: Mon Aug 18, 2014 9:06 pm
Awesome thanks for the assistance
PostPosted: Mon Aug 18, 2014 9:32 pm
We are here to help.
PostPosted: Mon Aug 25, 2014 4:15 pm
What ever you did it seemed to work out for you..
PostPosted: Mon Aug 25, 2014 8:46 pm
I am having a problem idling so I cut to whole copper piece and float off? And still plug the wire back in?
PostPosted: Mon Aug 25, 2014 9:50 pm
Just clip the wire off or plug it back up. Old solex's are bad about butterfly bushings going bad. Spray ether on them and see if it idles up for a second er 2.
PostPosted: Tue Aug 26, 2014 4:10 am
My tip is by a weber 40 and be done with that shit!;-)run it all the way up to a small stroker and still scream!!
PostPosted: Tue Aug 26, 2014 9:08 am
It will load up unburnt gas and wash the oil out of his rings. Then he looses compression and it becomes even harder to burn fuel. Then oil burning starts. Gas and oil fouled plugs. Hard to crank. Lost power. Unburned gas mixes and thins his oil and wears his bearings. My gripe theses days is $10/gal racing fuel in my a/c . My water cools love cheap pump gas. The computerized Passat adjusts timing so it can burn any gas plus it is very efficient.
PostPosted: Tue Aug 26, 2014 6:41 pm
No problems from it at all, even drove it to work monday!
I had a weber 40 IDF on my rail and it was nothing but problems with idle jets getting clogged and i even added jet doctor kit. stock carb has worked flawlessly since putting it back on
