It is currently Tue May 05, 2026 12:52 am
Post new topic Reply to topic  [ 525 posts ]  Go to page Previous  1 ... 12, 13, 14, 15, 16, 17, 18 ... 21  Next
PostPosted: Fri Jul 11, 2014 10:00 pm
Long story short.. got a new buggy and it spun 2 rod bearings the third trip out, and that wasin December... motor has been built for several months and i finally stabbed it in and fired it up couples weeks ago.. today i bolted up the motor cage and made sure everything was rite and tight, gunna take it out tomorrow and put a few hours on it 8)
LEGALIZE BLUEGRASS!!!
Save a tree... eat a Beaver
PostPosted: Tue Jul 22, 2014 1:22 pm
Built an extra tool box to hold mostly recovery tools. Somebody will eventually thank me..lol
PostPosted: Sat Jul 26, 2014 10:33 am
Washed mine it needed it also put on new blue bosch coil,,bled my brakes,,and added decalsto the body...
Nail it
PostPosted: Sat Jul 26, 2014 1:27 pm
Ripped all four lug nuts out of my high quality pos empi rotor and was passed by my own rear tire! Trail fixed and back at it
PostPosted: Sat Jul 26, 2014 5:57 pm
Changed out my rear torsion to what I thought (bought) was type 3. Turned out it they were type 1. Oh well maybe these havent their tension. The ones I bought were used. It would have cost more to send them back.
PostPosted: Sun Aug 03, 2014 8:53 pm
finished front brakes & separate pedal, now waiting on spacers to mount front wheels & im done.
ya cant beat fun!
PostPosted: Mon Aug 04, 2014 12:12 am
Greased the front wheel bearings.
PostPosted: Tue Aug 05, 2014 3:02 pm
Traded for a my first buggy a month ago. Hit the trials two weeks back and now I have a list of things to change or fix.
1) Throttle cable: It sucks change to Morse style
2) Fix front tire: Poked a hole right in the side of that one
3) Rear brakes: Looks like last owner forgot a spacer on the axel and rotor ate into mounting bracket
4) Isolate issue with alternator: I think I found that today. Loose wire not sending signal to voltage regulator.
As my wife already said " looks like your spending more time in the barn now with the buggy and not with me"
Im sure the list will continue to grow
PostPosted: Tue Aug 05, 2014 5:45 pm
I should of done that before my top speed run.... Left front locked up on me!
PostPosted: Tue Aug 05, 2014 5:47 pm
Yea..my last front spindle snapped. Now I keep them greased.
PostPosted: Wed Aug 06, 2014 11:11 pm
Picked up an electric steering box from a 03 Saturn Vue for my buggy.
PostPosted: Thu Aug 07, 2014 2:38 am
Did nothing today but tomorrow gonna put tube in tire set torsion and put new limit straps on fix throttle cable maybe clean it up and put some new wing nuts on my carbs then just need a brace on my shock mount and will be rdy for rush I hope
PostPosted: Thu Aug 07, 2014 4:55 am
Started mounting air bags Image
PostPosted: Thu Aug 07, 2014 10:02 pm
Give her a bath and a went over everything ready for Saturday rain or shine I'm riding! !!
PostPosted: Fri Aug 08, 2014 7:23 am
Looks good!!! Until I sling mud all over saturday!!!!:D hehehe!!!
PostPosted: Fri Aug 08, 2014 12:27 pm
Gotta catch me first. It's undergone a few changes since last time
Lol
PostPosted: Fri Aug 08, 2014 12:30 pm
Uh ohhh!!!! New secret weapon???
PostPosted: Sun Aug 10, 2014 3:42 pm
Got both bags mounted just need a better bottom mount
PostPosted: Sun Aug 10, 2014 8:41 pm
New battery box and battery.
Pulled rear wheels and started reworking the bearings and breaks
PostPosted: Sun Aug 10, 2014 8:43 pm
If you can use a pivot on the bottom mount it lets the top and bottom of the bag stay parallel. Also if you have a 9 inch travel bag make the mounts 9 inches apart at full droop.I
PostPosted: Sun Aug 10, 2014 9:35 pm
Started taking my black buggy apart. Pulled the motor. Took out the third seat in the back. Got trans ready to set out. Going to take it all apart and put a new rear housing in it. Change front from BJ to KP. Raise the roof and make a new back cage. Got lots of changes to make to have going by sept 13. Can't wait to put my madmike rear swing arms and new front arms on it. Chad :mrgreen:
PostPosted: Wed Aug 20, 2014 3:24 pm
Added eps, new wilwood calipers, and straightened rear arms. Ready for September 13th. Gonna have to learn how to drive it all over again:lol:
PostPosted: Wed Aug 20, 2014 4:07 pm
Il bring ya some ml !! That should do it :lol:
PostPosted: Wed Aug 20, 2014 6:40 pm
The ML always helps:D
PostPosted: Thu Aug 21, 2014 8:18 pm
screwed it up apparently :x wants to get stuck in third and not come out :x doesn't shift 3rd or 4th right :x :shock: :x I only need 1st and 2nd for Rush the 13th :mrgreen: :shock: :mrgreen:
cron
