It is currently Mon May 04, 2026 1:40 pm
PostPosted: Thu Jul 24, 2014 9:25 pm
Anyone using a setup like that. I have a line on the steering components from an 03. I don't know anything about them and want to make sure I have everything that's needed to make it work if I choose to use it.
PostPosted: Thu Jul 24, 2014 10:01 pm
I have done two of them they are the cats ass are you going to use a ebay controller or try to make one yourself I did the ebay one its simple basically plug and play. Make sure the ecm on the motor is metal supposedly the plastic ecm wont work all you really need is basically the top half of the steering column and the controller from ebay
PostPosted: Thu Jul 24, 2014 10:12 pm
Not sure what all is with it. I picked up a trailer today and the guy that was there offered what he had for a 100 bucks.. I told him I'd find out what all I needed and if it could be done.
PostPosted: Thu Jul 24, 2014 10:37 pm
you can use the rack and everything i believe they are the same as the cobalt racks some people use but like i said look under the dash and you'll see a electric motor in the steering column if it has a metal ecu on it your in or give me your number i'll send you some pics of what all is needed i'm not real savy for posting pics where abouts you from
PostPosted: Thu Jul 24, 2014 10:40 pm
problem is I've never found a metal ecu in an ion all I've found is plastics I always find mine in Saturn Vue they're the same steering
PostPosted: Fri Jul 25, 2014 9:08 am
I'm in the Ashland Ky area.. I'll pm you my number.
PostPosted: Fri Jul 25, 2014 1:06 pm
Brad (hillahollic) just put something similiar on his buggy.maybe someone can get him to chime in on this subject
PostPosted: Sun Jul 27, 2014 10:49 am
Went to the Pull and Steal on Friday. They had 4 Vue's. It took me about 30 minutes to get. Pretty easy. As soon as we got home we ordered the controller off E-Bay. Looks like it gonna be easy to mount and make work
PostPosted: Sun Jul 27, 2014 12:31 pm
Good deal! I think I might go that direction too..
PostPosted: Sun Jul 27, 2014 2:29 pm
7yr old Saturn Vue electric power steering: https://youtu.be/Y1bMoJQt7fw
PostPosted: Sun Jul 27, 2014 2:33 pm
http://youtu.be/1DCUs_Vn0_o
PostPosted: Sun Jul 27, 2014 2:39 pm
PostPosted: Tue Jul 29, 2014 7:20 am
John I'm ordering 5 more columns already had 15 and bought 15 controllers 3049625787 I will give you all the info
PostPosted: Tue Jul 29, 2014 11:48 am
Thanks! I'll give you a call within the next couple days..
PostPosted: Wed Oct 01, 2014 11:46 pm
Has anyone had an issue with the electric steering turning easier to the right than the left? I have contacted Bruno, the guy that makes the controller. Waiting on him to reply. Your input is welcome.
PostPosted: Thu Oct 02, 2014 7:30 am
He has a fix but don't know what it is
PostPosted: Thu Oct 02, 2014 10:49 am
I just got my reply from Bruno. You inside the ecu and make an adjust. I will try this when I get time.
PostPosted: Thu Oct 02, 2014 9:54 pm
FYI if anyone needs it. Inside the ECU is 3 potentiometers. The one marked VR1 is the one that needs to be adjusted either left or right depending on which way your steering is softer.
