It is currently Sun May 03, 2026 5:24 am
Post new topic Reply to topic  [ 143 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
PostPosted: Tue Jul 22, 2014 10:49 pm
Sent from my SM-G900V using Tapatalk
PostPosted: Tue Jul 22, 2014 10:50 pm
I bolted the motor in the buggy
PostPosted: Wed Jul 23, 2014 3:52 am
Looks sweet man :mrgreen: Cant wait to start my ecotech swap. Im so ready :mrgreen: :mrgreen:
PostPosted: Wed Jul 23, 2014 3:55 am
http://www.ebay.com/itm/141150286521?ss ... 1423.l2649 This is the one I was going to run.
PostPosted: Wed Jul 23, 2014 6:10 am
Looks good Darrell ,do you have to change the bars over the motor or will it work?
PostPosted: Wed Jul 23, 2014 4:12 pm
Everything is gonna work Mike ....Under carriage won't work the oil pan sits a little lower than the VW but hell i can deal with that ....i got lucky
PostPosted: Wed Jul 23, 2014 4:15 pm
Just keep the oilpan off the skidpan. I've busted one already
PostPosted: Wed Jul 23, 2014 6:03 pm
Looks good . How long and how tall is the engine ?
PostPosted: Wed Jul 23, 2014 11:06 pm
Its about this big!!!!!:mrgreen:wiring this was sweet with the way they label everything. Definately a good setup!
PostPosted: Wed Jul 23, 2014 11:21 pm
Just tossing something out there but couldn't you raise the back of the trans up some, just enough to not need to redo your under bars and skid pan. It would also improve your departure angle so less banging at the rear of the cage. Doing this is a little more than just jacking up the back of the trans but it might be worth looking into. If I recall correctly I pitched up my trans about 8 degrees lifting the motor up a couple of inches.
Just thinking out loud.
PostPosted: Thu Jul 24, 2014 12:07 am
An old semi truck mudflap cut to fit between the oil pan and skid-plate seems to help alot.
PostPosted: Thu Jul 24, 2014 10:17 pm
Looks good setting in there.
PostPosted: Fri Jul 25, 2014 1:47 am
It should be running tomorrow
PostPosted: Fri Jul 25, 2014 5:54 am
Get that thing goin and we'll go to rush in 2 weeks and try them out!!
PostPosted: Fri Jul 25, 2014 3:33 pm
Got most of the wiring done won't be long now
PostPosted: Fri Jul 25, 2014 3:34 pm
What are you guys doing for upper and lower radiator hoses?
PostPosted: Fri Jul 25, 2014 4:10 pm
Darrell I just used the flex hoses with a spring in them from my local parts house
PostPosted: Mon Jul 28, 2014 12:50 am
PostPosted: Mon Jul 28, 2014 6:49 am
Looks good brother!! Look like A.f.I made the wiring job alot easier!
PostPosted: Mon Jul 28, 2014 5:45 pm
Can any one give me some part numbers on a fuel pump ...My pump is not working wanting to use my stock tank with out a return ..And do i need a pressure reg. and if so what kind of pres. do i need ..My motor starts and will only run about 20 sec. and shuts off and wont restart ..Put a new set of plugs in and it restarted same thing ran just about 20sec. and dead
PostPosted: Mon Jul 28, 2014 6:25 pm
I think the 2.4 is different then my 2.2 on the fuel rail but mine has a return and the pump needs it I tried to run a tee with the return right at bottom of tank, and the pump over heated and got extremely loud, I ran a return to tank and now the pump stays cool and can barely here it even when the motor is off, the pump seems to like the fresh fuel constantly running through it. if your gonna run a system with no return better make sure the pump is designed for that. Fyi I used a universal walbro pump, got off eBay for 100
PostPosted: Mon Jul 28, 2014 7:51 pm
Im running a ac delco ep424 pump with a reg. If you dont want a return you should run a surge tank. Then just run the return in to it and never lose pickup. Also you can not hear the pump at all.
PostPosted: Mon Jul 28, 2014 7:57 pm
Also that pressure are you running if its to high it will shut off like that. And will not restart till it sets and drain back down.
PostPosted: Tue Jul 29, 2014 12:41 am
Yeah blue buggy that's exactly what it's doing I'm thinking
