It is currently Mon May 04, 2026 7:11 am
 Post subject: cv issue
PostPosted: Thu Jul 03, 2014 1:18 pm
new buggy, 2x3 arms,with all new bearings & spacers.6-rib trans , bus joints & axles. about 1/4" clearance between spring plate & torsion stop at ride height. neither has been ground down any. have free movement on both axles,"sliding in & out of cv's when its suspended & at ride height. put it together with my old axles & joints after a few rides the driver side, outside cv started squeaking.in side is ok. so I put a new joint on the outside, clocked it, ran it 1 ride & its doing the same thing. ran about 4 miles on the hiway back home & heard it as I pulled in the driveway. outside driver side joint hot , the other 3 just warm . cleaned up old cv & found some hair sized shavings around the ball slots in the cage. couldn't exactly tell which part they were coming from. joint had the ball groove worn in both inner & outer housing though, so I thought that was the issue. any ideas why im having issues with this .gonna take it apart sat. what do I need to look for to help solve this?
ya cant beat fun!
 Post subject: Re: cv issue
PostPosted: Thu Jul 03, 2014 7:36 pm
http://youtu.be/wsIn3z7dbjc
PostPosted: Thu Jul 03, 2014 10:11 pm
I've seen that, just don't understand that if the angle on both axles are the same & I've measured everything I can think of from side to side & it's all the same why is this happining? I understand something is out. But i can't understand what it is. Gonna polish on the joints this weekend to see if it helps. I just don't like tearing stuff apart not knowing what the prob is.
ya cant beat fun!
PostPosted: Thu Jul 03, 2014 10:22 pm
Check wheel bearings
PostPosted: Fri Jul 04, 2014 12:08 pm
Im not sure if you did any kind of prep work (grinding, polishing) to them before you put them in, but that helps a lot. They can be extremely tight from the factory... What kind of grease are you using?
PostPosted: Fri Jul 04, 2014 5:34 pm
Started with axles & joints i had on my old buggy, then put a complete brand new axle assy, last weekend & after the first ride, same issue- squeaks & hot.
ya cant beat fun!
PostPosted: Fri Jul 04, 2014 5:35 pm
Factory cv grease
ya cant beat fun!
PostPosted: Fri Jul 04, 2014 8:59 pm
Is stub spinning true in your bearing housing?
PostPosted: Fri Jul 04, 2014 9:14 pm
Yep, checked all that stuff when I put all new bearings in both sides, & again today when I took it apart again
ya cant beat fun!
