It is currently Mon May 04, 2026 4:49 pm
PostPosted: Wed Jun 18, 2014 4:10 pm
Please post pics of your Chevy Cavalier/Sunfire rack and pinion set ups. I printed some info from the site years ago and now I cant find it... :?
Ive tried searching the site but I suck at it... any help appreciated!!
Thanks in advance!
Mike
Got Honda?
PostPosted: Wed Jun 18, 2014 5:22 pm
I know this isn't what your looking for Mike. Couple of good reasons NOT to use car parts, try to save you some aggravation.
PostPosted: Wed Jun 18, 2014 6:22 pm
Hey Mike! I know and appreciate what your saying (cry once) but I'm broke and already have all the parts to do it...also if you bend one like in the pics you posted it's only $75 for another from the junkyard :)
And only need to run a couple lines for power steering down the road.... 8)
Mike
Got Honda?
PostPosted: Wed Jun 18, 2014 7:13 pm
Do not run a end load rack like in the pics I have one in buggy now the bump steer is horrible almost impossible to get to work descent, if your set on a car rack look into one from a early 90s grand am (I think) there a lot alike but there center load so you use long tie rods and are able to mount it close to the beam to eliminate bump steer. I think big d smith is running one you will have to fab a little to get tie rods to bolt on in the right spot but way easier than the bull I went through with this end load rack. Please save yourself the aggravation that I've already went through and forget the end load rack.
Sent from my QMV7A using Tapatalk
PostPosted: Wed Jun 18, 2014 7:41 pm
Imaged
Not the best picture. I cut turned and welded mine so I can mount on the front of my beam.
PostPosted: Wed Jun 18, 2014 9:05 pm
[attachment=-1]uploadfromtaptalk1403139163323.jpg[/attachment][attachment=-1]uploadfromtaptalk1403139186986.jpg[/attachment][attachment=-1]uploadfromtaptalk1403139211276.jpg[/attachment]
Been running mine for 2 years no problems. Very little to no bump steer, just put 400 road miles on it last weekend. I believe mine was off a 04. Im running stock link pin. I cut the rods back a few inches then drilled out some round stock the drill size for 5/8-18 was the size of the rod welded it on and I used heim joints.
PostPosted: Wed Jun 18, 2014 10:25 pm
I have longer than stock arms must not work so well seemed like there is not enough travel to get everything right
PostPosted: Thu Jun 19, 2014 9:35 am
Thanks guys!
Bluebuggy, my rack looks to be the same as yours, its off a 96 Cav 2.2 5 speed 8)
Mike
Got Honda?
PostPosted: Thu Jun 19, 2014 10:22 pm
Mines a 1995 Grand Am. Made a "u" shape 3/16" thick channel. Bolted to front of rack then bolted tie rods to the other side. That way rack is bolted against the torsion. Works pretty good.
PostPosted: Fri Jun 20, 2014 11:17 am
Sounds cool BigD, any chance of some pics?
Mike
Got Honda?
PostPosted: Fri Jun 20, 2014 10:09 pm
I will post some Saturday
PostPosted: Sat Jun 21, 2014 6:50 pm
[attachment=-1]uploadfromtaptalk1403390961842.jpg[/attachment][attachment=-1]uploadfromtaptalk1403390977674.jpg[/attachment][attachment=-1]uploadfromtaptalk1403390996725.jpg[/attachment]
This is my 95 Grand Am R&P setup.
PostPosted: Sun Jun 22, 2014 12:08 pm
why is the left heim bolted lower on the rack?
PostPosted: Sun Jun 22, 2014 12:22 pm
I think I needed the clearance for the arm to clear the frame.I really cant remember.
PostPosted: Sun Jun 22, 2014 2:54 pm
I remember now. I didnt use a steering universal joint out of the Rack. So I needed more
clearance under the steering coupler. If I used a u joint I could have twisted the rack up and it would have cleared the tie rod.
PostPosted: Sun Jun 22, 2014 2:57 pm
Under full suspension compression the tie rod would barely hit the steering coupler.[attachment=-1]uploadfromtaptalk1403463464348.jpg[/attachment]
