It is currently Sun May 03, 2026 2:40 pm
PostPosted: Sun Jun 15, 2014 5:30 pm
the reason for posting here is help deciding what rear suspension to use. I want to use VW parts mainly cv joints axles and stuff. I was thinking either a VW style trailing arm suspension or an a-arm type. any thoughts?
I may not know alot about working on cars, but I know enough to be dangerous.
PostPosted: Sun Jun 15, 2014 5:51 pm
IMO stick with VW unless you want to get intoA arm susp geometry.
PostPosted: Sun Jun 15, 2014 6:00 pm
Here is pics of my set up. It's a Jeffco diff with reverse. The rest is VW based- arms,axles and cv'sImage
PostPosted: Sun Jun 15, 2014 6:06 pm
where did you get the diff and it had to of been an arm and a leg.
PostPosted: Sun Jun 15, 2014 6:13 pm
Here yea go..... http://www.jeffcoperformance.com/Revers ... rmance.php
Not cheap for sure. If you don't need a open differential they is the RPM box, about 1/2 the price. If your not looking for reverse there is even cheaper options
PostPosted: Sun Jun 15, 2014 6:20 pm
I believe ill do without reverse. how much does your buggy weigh?
PostPosted: Sun Jun 15, 2014 6:30 pm
1300lbs
PostPosted: Fri Jun 20, 2014 8:02 am
They do sell couplers to hook bike engines to VW trans axles. You have to turn engine sideways though.
PostPosted: Mon Jun 23, 2014 8:57 pm
If you do not want reverse then using a VW diff with the open holes welded up is another option.
PostPosted: Tue Jun 24, 2014 8:12 am
when i built my motorcycle powered rail I did alot of investigating on trans and gearboxes. The best one out there has to be the Jeffco if you want a diff but it is costly. The RPM is a real good one if you don't want a diff and it is half the price as a Jeffco. The transworks trans does not hold up very well from what everybody told me. You have to turn the bike motor side ways to make this one work. There is a site called minibuggy.net go there and look around.
