It is currently Sun May 03, 2026 12:13 pm
 Post subject: IRS pivot bolt snapped
PostPosted: Fri Jun 06, 2014 2:25 pm
I snapped the pivot bolt for the trailing arm pivot. It broke flush with the threads inside the frame horns. Anyone else have this problem before.
PostPosted: Fri Jun 06, 2014 3:21 pm
welded a washer to the broken bolt then welded a nut to the washer. A little bit of heat and it came right out.
PostPosted: Fri Jun 06, 2014 8:03 pm
Good work! I like crafty people. Crafty people come up with genius fixes to get me out of a hole and out of the woods. I depend on these folks after my 12th. That's why I pack a 30 pack. I'm on 11 now. I am trying to figure 5 big terrorists for 1 deserter. chipop, gulp gulp gulp. 12.
PostPosted: Sat Jun 07, 2014 6:22 pm
I'd make sure your trailing arm isn't bent or in a bind.
PostPosted: Sat Jun 07, 2014 10:27 pm
Its good. The frame sat outside for alittle while
PostPosted: Mon Jun 09, 2014 7:07 am
Loose ones break.
PostPosted: Mon Jun 09, 2014 7:37 am
This one was seized up. I had a cheater bar on the ratchet and broke the bolt.
PostPosted: Thu Jun 19, 2014 7:30 pm
Had that happen once. Cut the old mount out and get one of the ones people use to convert swingaxle to irs and weld it in.
PostPosted: Fri Jun 20, 2014 12:19 am
SOMEBODY told ME. bE CAREFUL WITH THE AFTER MARKET NEW ONE. yOU BETTER HAVE IT LINED UP RITE! RUN A TAP THRU THE OLD ONE AND CLEAN UP THE THREADS. NOT TRYING TO BE A KNOW IT ALL. tHEN PUT SOME LOCK TITE ON IT.
PostPosted: Fri Jun 20, 2014 7:31 pm
I got it lined up right but I put anti-sieze on it. Every thing I work on either gets locktight or anti-sieze :shock:
