It is currently Sun May 03, 2026 2:04 pm
PostPosted: Mon May 12, 2014 12:52 am
Im running a 1915 with a type 3 turbo. Because of the high CR under boost I need to run race fuel. Anyone see any harm in running 105 leaded fuel? Thanks in advance for the response.
PostPosted: Mon May 12, 2014 7:47 am
No it shouldn't I've been running 111 racing fuel for 10 years now no problems I think air-cooled motors are design to run on leaded fuels everybody I ride with runs racing fuel
PostPosted: Mon May 12, 2014 9:20 am
If your running a wide band or any o2 it will burn it up. It may also get your map if fuel hits it. If your running any of this with your turbo setup.
PostPosted: Mon May 12, 2014 1:35 pm
Don't know about the turbo stuff but an a/c motor runs good on leaded gas. A lot guys run the leaded aviation fuel and also some add the lead additive to them. They was designed to run leaded fuel. Chad :mrgreen:
PostPosted: Mon May 12, 2014 4:23 pm
Thanks all. I figured it would be fine and lead is a good lube for the engine. Win win. :mrgreen:
Users browsing this forum: No registered users and 5 guests
