It is currently Sun May 03, 2026 10:27 pm
Post new topic Reply to topic  [ 525 posts ]  Go to page Previous  1 ... 10, 11, 12, 13, 14, 15, 16 ... 21  Next
PostPosted: Fri May 09, 2014 11:33 pm
I got a lot done today on ss. Tabs welded in. More work tomorrorow
Dirtdobber
PostPosted: Sat May 10, 2014 12:50 am
Yea I walk by it and pee on the back tire so maybe it will better grip next time I go riding
PostPosted: Sat May 10, 2014 7:34 am
I BOUGHT A BAD ASS FRAME FRIDAY ,AM TAKING IT TO WELDER TODAY FOR A COUPLE MODIFICATIONS AND THEN WILL B WORKING EVERY NIGHT TO HAVE IT IN THE WOODS THIS COMING WEEKEND :D 8) 8)
PostPosted: Sat May 10, 2014 7:38 am
Beat the piss out of it t rush :)
PostPosted: Sat May 10, 2014 8:20 pm
WELL I GOT MY WELDING DONE,NEW BALL JOINTS AND A COAT OF PAINT,PULLED THE MOTOR AND AXLE AND FOUND A CRACKED PUSH TUBE I HATE BREAKING MOTOR DOWN TO REPLACE IT BUT WHAT'S A N****R SUPPOSED TO DO OH WELL GOTTA KEEP PLUGGIN AT IT IN ORDER TO BE IN THE WOODS SATURDAY :roll:
PostPosted: Sat May 10, 2014 9:01 pm
Take off your rockers pull out the push rods and just bend rip pull out the tubes and put spring loaded push rod tubes in at least you won't have to pull off your heads and you can do it in an evening. Just an idea
PostPosted: Sun May 11, 2014 7:38 am
YEA GOOD IDEA,THAT HAD BEEN MY PLAN,SMALL FRYES IN BHAM DOES'NT OPEN TILL MONDAY STILL HAVE PLENTY OF THINGS TO DO TODAY TO B READY FOR FLIPPINDALE SAT LOL :lol:
PostPosted: Sun May 11, 2014 11:57 pm
WELL I GOT MOTOR ON,TURNING BRAKES MOUNTED ,MOST OF THE WIRING DONE,LETS SEE ...STILL HAVE TO MOUNT FRONT SPINDLES,PUT IN NEW SEATS AND HARNESSES AND THE TWO MOST IMPORTANT ITEMS THE COOLER AND TOOL BOX STILL LOOKING LIKE FLIPPENDALE IS POSSIBLE WOOOO-HOOOOOO!!
PostPosted: Mon May 12, 2014 6:45 am
PostPosted: Mon May 12, 2014 12:19 pm
Put new points in buggy last night and fired it up for the first time. Throttle cable, small adjustments on the carb and put exhaust back on and just about ready to tear shat up! :twisted:
It makes perfectly good sense if ya don't think about it.
PostPosted: Mon May 12, 2014 10:02 pm
thanks for the pic help ron,i've got 5 MASTER CYLINDERS AND CAN NOT GET ONE OF THEM TO HOLD PRESSURE ORDERED3 KITS JUST IN CASE WENT AND BOUGHT SPRING LOADED TUBES TODAY BOUGHT 4 ENDED UP WITH 3 WHEN I GOT HOME SO MY MOTORS WIDE OPEN TONIGHT WAS SUPPOSED TO GET BALL JOINTS ON MY SPINDLES TODAY BUT THAT DID NOT HAPPEN :( :( :(
PostPosted: Thu May 15, 2014 11:21 pm
well it's done and running went on my maiden voyage today i'm hooked up now stilll going to have to buy a new master cylinder got lot more go than whoa LOL 8)
PostPosted: Sat May 17, 2014 10:22 pm
Put my old tranny back in.
PostPosted: Sun May 18, 2014 10:56 pm
Roof on , floor in ss. I'm getting trailing arms from Bobby Belk this week.next is steering box mounted and wiring!!! Then I'm going:)
Dirtdobber
PostPosted: Mon May 19, 2014 7:04 am
Put on the stones
PostPosted: Mon May 19, 2014 7:52 am
Thats a good lookin cut on the stones .do they do better like that?
PostPosted: Mon May 19, 2014 7:59 am
I think they are a little softer in the middle this way. I just like the way they look
PostPosted: Mon May 19, 2014 8:09 am
NRIbuggys wrote:
Put on the stones
If there is one thing I have learn on WB, is that those tire are not near tall enough and far to wide to be in Alabama. So you can ship them up north to me! Lol 8)
PostPosted: Mon May 19, 2014 11:01 am
WB Competitor
60/40 cut...same cut pipedope use to run. he said they did real good cut like that.
PostPosted: Mon May 19, 2014 5:19 pm
Pulled the motor, pulled the trans, drained the trans with several ring and pinion teeth. Anyone got any spare ring gear teeth mine are screwed. Wish I could say I did it climbing a monster hill, no just on the trailer Easter weekend. Just back in town long enough to pull the trans to take to Mr. jones in Kentucky. Headed up to Louisville in Wednesday for the next three or so weeks.
Debating about stripping the limo down and parting it out. Time for a new build
PostPosted: Tue May 20, 2014 3:25 am
HELP!!!!i need help finding the best price on a cnc master cylinder,who to order it from and how much
PostPosted: Sat May 31, 2014 8:34 pm
Change tender spring on rear to a 275# to soften it up a bit.
PostPosted: Sat May 31, 2014 11:49 pm
Re adjusted my torsion bars. Twice
PostPosted: Sun Jun 01, 2014 12:07 am
Put my light bar on
Dirtdobber
PostPosted: Sun Jun 01, 2014 7:52 am
Spent about 8 hrs tryin not to turn over lol!Image
