It is currently Sun May 03, 2026 4:28 am
Post new topic Reply to topic  [ 62 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: Suby build
PostPosted: Wed Mar 05, 2014 11:37 am
do you remember what size top and bottom like 375's or 450's etc.
PostPosted: Wed Mar 05, 2014 2:53 pm
Not too sure I can tell you that.. Not for a race buggy any way. :wink:
PostPosted: Fri Mar 07, 2014 8:18 am
It looks like I am around 400 over 500. I have a ton of spring boxes and those seem to be the heaviest. But with that boat ancor your running, you might need to run 800 over 1000s! hahaha!@!! :twisted:
PostPosted: Fri Mar 07, 2014 2:07 pm
Where's hyde been :?:
PostPosted: Fri Mar 07, 2014 4:23 pm
hes been Hydeing! hahaha I know hes been working on some motors here and there.
PostPosted: Mon Mar 17, 2014 3:50 pm
we got around to measuring all the oil clearences this weekend at sattlers dyno shop.
.0025 for the rods and .0035 for the mains
and we honed the wrist pin holes on the rods and pistons
and balanced the pistons
time to get the bottom end bolted up!
PostPosted: Wed Mar 19, 2014 7:29 am
I bolted a rod on the crank and checked the side clearence and it is only .012-.013" . Sounds tight, but the book says it is good!
PostPosted: Wed Mar 19, 2014 8:21 pm
Can't wait to see it run !
PostPosted: Fri Mar 21, 2014 7:40 am
I got the case bolted together last night. SOo much easier than a VW! No cam, lifters, timing, or anything else. Just stand on one side of the room and throw the crank across the room and into the block and tighten it up!! :mrgreen:
then you have to line up the rods and pistons up and push the wrist pin and clips through that little hole there... I cant wait!
PostPosted: Mon Mar 24, 2014 8:49 am
This thing has about 5 times the parts that a air-cooled motor does!! I spent hours elbow deep in the parts washer this weekend. I did get the heads on it finally. Now I am waiting on the valve shim buckets before I can install the new cams and start screwing around with timing it.
pistons installed
ARP head studs
valves unshrouded
ported
heads on
waterpump and oil pump installed
PostPosted: Mon Mar 24, 2014 10:50 am
Making progress now 8)
PostPosted: Mon Mar 31, 2014 1:41 pm
got the motor in this weekend, but I'm still waiting on my valve shim buckets to show up before I can put the cams in. I also figured out several of my fuel lines are leaking after sitting for a few years. I figured them AN lines would be fine, but I guess not!
PostPosted: Fri Apr 04, 2014 7:14 am
I was looking into making a dual throttle body set up. This one looks cool!
http://youtu.be/ta6iJiKbfHg
http://forums.nasioc.com/forums/showthr ... ?t=2611843
http://www.tomeiusa.com/_2003web-catalo ... 4thro.html WOW!! i wonder if that price includes the motor!!
PostPosted: Fri Apr 25, 2014 9:51 am
Update??????????????????
PostPosted: Fri Apr 25, 2014 2:40 pm
update is grass is growing, yard work crap and it took 3 weeks for the correct shims to arrive for the valves. I could have it running in a few hours, but am trying to degree in the variable cams so I don't have a little engine crash when they advance. Hope to have it done and ready for the dyno in a few weeks.
PostPosted: Fri Apr 25, 2014 2:54 pm
How are you controlling the AVLS? RPM trigger from the ECU? or are you using the stock ECU with a piggy back?
PostPosted: Fri Apr 25, 2014 3:16 pm
stand alone Hydra ems. The cam timing has its own map. Since it has never been on a dyno, i havent been able to play with it yet. The base map it has is for a turbo set-up so it barely did anything with just a vacuum reading.
PostPosted: Fri Apr 25, 2014 4:35 pm
Having a 15,000 original mile motor I decided to go with the stock ECU. 174HP should be plenty until the motor breaks in, another 15,000 mile or so. Playing with the idea of adding a supercharger
OH, if you need a test pilot, let me know. I can free up some time for ya. 8)
PostPosted: Mon Apr 28, 2014 7:23 am
With how busy i have been, I will need a test pilot and a hired hand just to race it! :mrgreen:
PostPosted: Mon Apr 28, 2014 6:44 pm
Slow as we are I could start in a week. I even have my own suit and helmet
PostPosted: Mon Apr 28, 2014 8:31 pm
Nice shed and nice ride! But a lot of chemicals soak thru your skin and into yer blood, then to liver and kidneys.wear em gloves and masks.
PostPosted: Thu May 08, 2014 12:12 pm
I am having a hell of a time getting the cams timed. since I had them welded and reground and had the heads milled, I cannot get the centerlines to match up. This is turning into a real pain!!
PostPosted: Mon May 19, 2014 7:55 am
I finally got the cams all timed this weekend! I had to first time the intake cams in there static position, then advance them to my projected position and check piston to valve clearance. These things will advance 30 cam degrees (that 60 crank degrees)! That will lead to an engine crash! I had to figure out what my max advance was and make stops for the variable pulleys. that only took a few tries :roll:
I had to keep making spacers and then re-time it and chack the centerline and clearance
one of my sets of stops
PostPosted: Thu May 22, 2014 7:09 am
Its alive! Started it up and broke in the cams last night. everything went extremely smooth. it only took 3 years to build!! :mrgreen:
PostPosted: Thu May 22, 2014 12:33 pm
Cool!!!!! Video??????
