It is currently Sat May 02, 2026 11:26 pm
 Post subject: Radiator Pluming
PostPosted: Thu Apr 24, 2014 10:57 pm
What is every one using for Pipe when they are pluming in there radiator? My buggy I just picked up as a 2.3 ford and the previous owner just ran rubber hose and it looked like shit, So I am wanting to hard line as much as possible and run as little rubber hose as I can
 Post subject: Re: Radiator Pluming
PostPosted: Fri Apr 25, 2014 12:29 am
I went with http://www.allpurposepipes.com/ for almost everything including my intake.
PostPosted: Fri Apr 25, 2014 8:54 am
you can go to the local exhaust shop and have them bend exhaust tubing however you like it. connect it with short pieces of hose.
PostPosted: Fri Apr 25, 2014 9:45 am
I bought 1.5" mandrel bent 180's then u can cut them as needed and weld to 1.5 " tubing. I used silicone rubber ftgs to connect to the block and radiator. I bought the 180's, tubing and the hose from Foddrill Motorsports retail store in Phoenix.
PostPosted: Fri Apr 25, 2014 10:14 am
mandrel bent tubing, I suggest using stainless or aluminum
http://www.woolfaircraft.com/index.html
I use silicone hose as well
http://www.siliconehose.com/
PostPosted: Fri Apr 25, 2014 12:29 pm
Thanks guys for the help
PostPosted: Sat Apr 26, 2014 3:05 am
I used flex hose
PostPosted: Sat Apr 26, 2014 3:39 pm
So I have been Trolling on the net and I have found a set up that I would like to use for the buggy but iam not sure if it will work.
So I found the radiator I want and it uses a lot smaller line, I would be using -12an fittings with a -12 to 1.5 inch adaptor, My concern is the reducing it to much? Will I run into a cooling issue or pressure issue?
PostPosted: Sat Apr 26, 2014 7:33 pm
It's pretty simple. Use the same size rad that came in the original car. Length X height X thickness, make the rad cubic inches the same or more, you won't have any problems. Don't restrict the flow and keep it simple.
PostPosted: Sat Apr 26, 2014 7:46 pm
Ok thanks, I was just wanting to clean things up a bit, Drive me nuts when it looks like a rats next
PostPosted: Sat Apr 26, 2014 11:51 pm
My recommendation is to install the largest radiator you can for the space provided.
PostPosted: Mon Apr 28, 2014 7:27 am
I'm using 1.5" alloy pipe with silicone flexi's. And I'd echo the above about a big radiator - you'll be running higher throttle openings at much lower airspeeds than a road car, so if you use the buggy hard for any length of time with normal rad, you'll have to keep backing off to let it cool again.
