It is currently Mon May 04, 2026 4:28 am
 Post subject: T Trailer build.
PostPosted: Wed Apr 23, 2014 11:58 am
Does anyone have a good plan layout for a T trailer build? I have an axle out of a mobile home that was scrapped out. I belive its a 3500lb axle. Any help would be much appreciated! Thanks.
It makes perfectly good sense if ya don't think about it.
 Post subject: Re: T Trailer build.
PostPosted: Wed Apr 23, 2014 12:20 pm
here are my plans for a t trailer and an h trailer
T this is the t
H his is the h
just add wheels and a hitch
PostPosted: Wed Apr 23, 2014 5:36 pm
I have a boat trailer I made into a trailer for my buggy like to sale 500 Knox ten 865-258-1187 or 865-258-1244
PostPosted: Wed Apr 23, 2014 10:38 pm
I heard mobile home axles are illegal. Maybe just here in Al. I think they should make 2 story mobile homes for rich fokes. :lol:
PostPosted: Thu Apr 24, 2014 9:25 am
Axle should have been scrapped too. Tires are funny size and expensive.bearings are hard to find. They were made to be towed to one spot and rot! Id go a different route!!
PostPosted: Thu Apr 24, 2014 11:22 am
X2 what Dave said
Dirtdobber
PostPosted: Thu Apr 24, 2014 5:00 pm
Well I have 4 axles, All parts at cost thru work. Bearings for these axles are a dime a dozen and tires are actually cheap. But thanks for the help. Tstrange, any way you could send me a pic of trl for sale? Kind of far drive from Ohio but I may be up for a vacation. haha, been a few years since ive been down to TN. Thanks.
PostPosted: Thu Apr 24, 2014 6:40 pm
I just built a trailer out of a boat trailer here is the pic of it Image
PostPosted: Fri Apr 25, 2014 6:03 pm
I converted my car hauler with mobile axles and I works great . I put 6 bolt trailer hubs on it . Drink a few beers and think about it .
PostPosted: Fri Apr 25, 2014 9:28 pm
Mobile home axles work fine and parts are cheap for them. A lot of guys around here run them. I have one that has an old drop axle out of a horse trailer. I used 2" pipe for my T and side braces. Then I took a piece of 2" x 1/4" angle and turned it up and ran it to my front stop brace from the back on an angle. Then put a piece of angle turned down on bottom of the front of buggy. When the front wheels came up over the trailer axle the angle iron on the bottom of buggy would line up in the V of the angle iron on the trailer and keep the buggy straight. Had a hole drilled through on the front and would put a hitch lock through it and then the front couldn't move and was locked to the trailer. Make your ramps permanent with a flat paddle on the top so when you drive up on they raise up behind your wheels. Put two ratchet straps over each rear tire and your done. The buggy suspension will work as the trailer suspension and ride better this way. Chad :mrgreen:
PostPosted: Mon Apr 28, 2014 11:50 am
Thanks for the help guys. May stop down and get a couple pics and measurments off your trailer Jason. Ill give you a call one weekend. thanks again.
PostPosted: Wed May 21, 2014 9:43 am
[quote="tstrange"]I have a boat trailer I made into a trailer for my buggy like to sale 500 Knox ten 865-258-1187 or 865-258-1244
