It is currently Sun May 03, 2026 9:16 pm
 Post subject: Spindle Bearings
PostPosted: Wed Mar 19, 2014 11:43 pm
I want to upgrade my front spindles from ball joint to either combo or King Kong spuds. Question is: Do they make bearings for the bigger spuds that will allow me to use my 4 lug ball joint drums?
 Post subject: Re: Spindle Bearings
PostPosted: Thu Mar 20, 2014 12:32 am
Just went threw all this you will need a wide five hub or rotor and buy a wheel adapter thays 5 to 4
PostPosted: Thu Mar 20, 2014 9:53 am
Hey Jesse, I here about wide 5 all the time. Just exactly what is wide a wide 5. Is it a standard race hub? Where do you get them?
PostPosted: Thu Mar 20, 2014 12:37 pm
I think the wide five is just a stock five lug Volkswagen hub or rim
PostPosted: Thu Mar 20, 2014 1:02 pm
VW 200 mm stud pattern, not to be confused with late model dirt track wide 5.
PostPosted: Thu Mar 20, 2014 5:35 pm
5x205mm stud pattern
WTFO
Loud pipes save lives.
PostPosted: Thu Mar 20, 2014 6:10 pm
Wide five is just a kingpin hub they are five lug and baljoint is 4
PostPosted: Thu Mar 20, 2014 6:34 pm
So
What I need is the old vw 5 lug hub and a combo spud with what bearings??
PostPosted: Thu Mar 20, 2014 7:55 pm
This if im not mistaking let someone else confirm
http://www.tweedsdesigns.com/img/pages/ ... shore.html
PostPosted: Thu Mar 20, 2014 8:28 pm
You will need a hub something like this
http://www.appletreeauto.com/BILLET-FRO ... AC407008C/
PostPosted: Thu Mar 20, 2014 9:08 pm
You can run a stock hub just need right bearing but the ones liked look nice
PostPosted: Thu Mar 20, 2014 10:25 pm
The bearings in the link above will work on both stock wide 5 drums and for the billet hub from Appletree. I am running the billet hubs on my Funco.
PostPosted: Fri Mar 21, 2014 10:27 pm
Thanks guys. That's what I needed.
