It is currently Mon May 04, 2026 2:25 am
Post new topic Reply to topic  [ 160 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7  Next
PostPosted: Tue Apr 23, 2013 10:46 pm
got my shock mounts fabbed. they look kinda tall and block my headlights a little but they work :D
PostPosted: Sat Apr 27, 2013 5:14 pm
shock mounts done and painted. shocks mounted. shocks pull suspension up about an inch from full droop. wish i wouldve only gone a half inch. maybe once i get the front wheels mounted they wont look so tall. what do you guys think? (honestly)
PostPosted: Sat Apr 27, 2013 9:58 pm
Looks familiar...... I like it! :)
PostPosted: Mon Jun 03, 2013 1:17 pm
ok its been awhile since any progress but i finnaly got some "completed" pics (nothings ever finished)
its not buggy of the month material but i love it. I have never even rode in a buggy before building this thing but now im hooked. I started building this thing shortly after my dirtbike got stolen (about 2 years ago) I havent even been offroad since my bike got stolen but LOOKOUT world im back :lol:
i would like to thank EVERYONE on this site for helping me through this. it wouldnt be nearly the buggy it is without all of your help. THANK YOU.
now i remember alot of you guys inviting me to ride when this thing got done IM READY. ive pissed off the neighbors and local law enforcement enough by working out the bugs in the field across the street now its time for some real riding.
PostPosted: Mon Jun 03, 2013 1:22 pm
and just incase everyone skipped straight to the pics, I would again like to thank EVERYONE on this site for helping me through this build. you cant get this level of knoledge from facebook.
PostPosted: Mon Jun 03, 2013 4:08 pm
Looking at the megaphone your neighbors may have a point :wink: Great job and I really like the Cuda clone color!
PostPosted: Mon Jun 03, 2013 4:20 pm
Looks good hope to see it in wellsville soon!
PostPosted: Wed Jul 03, 2013 4:38 am
Cool build. Love the color. Can I ask what is your wheel base? I currently have a 2 seater that I am thinking about making it a 4 seater. Thanks.
PostPosted: Wed Jul 03, 2013 11:37 am
Thanks. If I remember correctly my wheel base from stub axle to spindle is 112" ill remeasure tonight to make sure.
PostPosted: Wed Jul 03, 2013 12:44 pm
Nothing feels better than building something for yourself. Looks good lovin the color also. You may want to put some limit straps on your front shocks if they are 1" shorter than the front being fully extended. Could pull the rod out of the shock body or break at the top bolt. Now we need some muddy pics,lol. Chad :mrgreen:
PostPosted: Wed Jul 03, 2013 2:52 pm
thanks chad. I posted some muddy pics in "videos from haspin" :D
PostPosted: Sat Feb 01, 2014 8:37 pm
have not posted here in a while so thought id bump it :lol: not much has changed but theres I few things ive posted in other threads just putting them here for no other reason than im bored. got the engine back together for the 3rd time this time with straight cut cam gears, ported the heads cleaned up the combustion chambers, gasket matched the intakes (required some welding to shift the holes a bit thanks to empi), homemade u exhaust with a glasspack. external oil cooler with fan and thermo switch, and a little more chrome. got some wider back wheels
everything seems to be holding together this time (knock on wood) sounds like a crotch rocket with the glass pack muffler.
next upgrade is going to be cutter brakes and some more roll bar padding and maybe ditch the dash panel for a console.
PostPosted: Sat Feb 01, 2014 9:03 pm
Glad to hear it's back to life, now you can ride once the tundra thaws
PostPosted: Sat Feb 01, 2014 9:16 pm
thanks barron, got up to 51 today so I got in a small ride in the field across the street. all this snow melting made it a muddy mess but it was enough to get my fix.
PostPosted: Sat Mar 01, 2014 9:27 pm
Started upgrading my brakes today. New brake pedal. Howe dual master pedal with balance bar for proportioning bias. 2 wilwood 3/4" masters.
Sent from my LG-P769 using Tapatalk
PostPosted: Sat Mar 01, 2014 9:45 pm
PostPosted: Sat Mar 01, 2014 9:48 pm
Gas pedal and cutter brake supposed to be here Monday. Also ordered a vacuum advance distributor and a console to replace my dash.
PostPosted: Sun Mar 02, 2014 5:52 am
Where did you get your pedals?
PostPosted: Sun Mar 02, 2014 8:52 am
I got them at jegs because I live by the store but im sure summit sells the same thing. the clutch pedal is a whole kit http://www.jegs.com/i/Wilwood/950/340-1469/10002/-1?parentProductId=744524
the brake pedal http://www.jegs.com/i/Howe/505/52692/10002/-1?parentProductId=1524882
masters http://www.jegs.com/i/Wilwood/950/260-1304/10002/-1?parentProductId=755319
PostPosted: Sun Mar 02, 2014 10:23 am
Thanks, I need some....
PostPosted: Sun Mar 02, 2014 4:22 pm
a quick startup and walkaround before I started changing things.
PostPosted: Mon Mar 03, 2014 11:37 pm
Got some goodies today. Started working on the console. Trying to mock up where I'm going to bolt the console. Thought about notching the back of the console to slide it back a bit further and slightly cover the cutter brakes.
PostPosted: Mon Mar 03, 2014 11:40 pm
PostPosted: Wed Mar 05, 2014 10:05 pm
Damn I hate wiring. I'm to meticulous about it. I hate any wires showing.
PostPosted: Thu Mar 06, 2014 11:29 am
I also like it when no wires are showing. Being meticulous isn't such a bad thing. Its looking great - build it so your happy with it!
Sent via TapaTalk
