It is currently Sun May 03, 2026 12:22 pm
Post new topic Reply to topic  [ 35 posts ]  Go to page Previous  1, 2
PostPosted: Fri Feb 28, 2014 10:53 pm
I'm thinking 14x1.25
Let's see what HP freak comes up with.
PostPosted: Sat Mar 01, 2014 8:34 am
Mine are 10x1.25
Sent from my LG-P769 using Tapatalk
PostPosted: Sat Mar 01, 2014 8:56 am
Just bought a new set with brackets. 56.00 can't beat them
PostPosted: Sat Mar 01, 2014 1:00 pm
Your right hpfreak. Mine are 10 also. Don't know what I was thinking of.
PostPosted: Sat Mar 01, 2014 1:35 pm
Yeah some reason I remembered them being a big bolt as well
PostPosted: Sat Mar 01, 2014 1:39 pm
Got mine at Tractor Supply. I had to cut them a little shorter so they would hit the disk.
PostPosted: Sat Mar 01, 2014 1:40 pm
bigDsmith wrote:
Got mine at Tractor Supply. I had to cut them a little shorter so they would not hit the disk.
PostPosted: Sat Feb 28, 2015 12:43 pm
hpfreak wrote:
advance auto part numbers:
calipers: slc8664
slc8665
pads: emkd 275
since youre thinking about using these im assuming you have a 3/8" rotor
do you have a part number for the rubber brake hose and banjo bolt? thanks E
PostPosted: Sat Feb 28, 2015 1:26 pm
I had my hoses made to fit my arms to my pivot point.
PostPosted: Sun May 29, 2016 12:26 pm
what size banjo bolt does the sentra calipers use?
