It is currently Mon May 04, 2026 11:16 am
Post new topic Reply to topic  [ 70 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Fri Jan 11, 2008 4:42 pm
With my truck a 24' would be the max that I would want to handle with these East Tennessee hills and such a small motor. 24' would give me the room I want and be able to do what I have planned on.
The Wild Kids
PostPosted: Fri Jan 11, 2008 5:11 pm
baddvw, have you had head gasket and head stud problems with that '03 6.0 yet? they are very common for that. there isa dealership in canton called mullinax ford that will replace the head studs with ARP studs. just curious.
PostPosted: Fri Jan 11, 2008 6:06 pm
[quote='The Wild Kids']With my truck a 24' would be the max that I would want to handle with these East Tennessee hills and such a small motor. 24' would give me the room I want and be able to do what I have planned on.
The Wild Kids[/quote]
What have you got for a truck?
PostPosted: Fri Jan 11, 2008 7:42 pm
I think he has a Ram 1500? I don't think that would pull a 24' trailer very well. He would have to check the rating for that truck.
PostPosted: Fri Jan 11, 2008 8:50 pm
Ram 1500 with HEMI is rated to pull 9000 lbs
PostPosted: Fri Jan 11, 2008 8:57 pm
Jeffclay chad just had new heads and head studs put in it.
PostPosted: Sat Jan 12, 2008 1:04 am
a hemi rated at 9000 lbs and 3 mpg
PostPosted: Sat Jan 12, 2008 1:23 am
[quote='purplerail']a hemi rated at 9000 lbs and 3 mpg[/quote]
Only if there's a tailwind! :twisted:
PostPosted: Sat Jan 12, 2008 9:33 am
Thats why I bought a Cummins!!!
PostPosted: Sat Jan 12, 2008 11:03 am
[quote='JeffClay']baddvw, have you had head gasket and head stud problems with that '03 6.0 yet? they are very common for that. there isa dealership in canton called mullinax ford that will replace the head studs with ARP studs. just curious.[/quote]
I already had problems with the 6.0L, the head gaskets blew around Thanksgiving Day, it occured around 68,000 miles and I had them replaced with head studs for the warranty work=$100 studs=$450. They went ahead and put on new heads,
PostPosted: Sat Jan 12, 2008 11:04 am
[quote='JeffClay']any interior shots of that trailer baddvw?[/quote]
I will have some pics soon as I can.
PostPosted: Sat Jan 12, 2008 11:08 am
[quote='The Wild Kids']Guess your right not that much difference in it. Then I can do what I want for the camper side of it and have more room.
The Wild Kids
What is the weight of that trailer? Looking to see if my truck could even pull it loaded. Thanks[/quote]
The weight of the trailer dry is 5550#, it is rated for 12k# GVWR my truck pulls it just fine loaded around 9500# total with 2 buggies, and other stuff in it and it gets around 14MPG pulling it, and around 17-18MPG
PostPosted: Sat Jan 12, 2008 11:12 am
[quote='Roy']I think he has a Ram 1500? I don't think that would pull a 24' trailer very well. He would have to check the rating for that truck.[/quote]
I think the ram will pull it just fine, it depends on what gear ratio it has. Common size is 3.73, should have a 4.10, usually special ordered on 1500 trucks with towing packages.
PostPosted: Sat Jan 12, 2008 11:18 am
[quote='turboblue'][quote='The Wild Kids']I want a trailer like that, just not that long.
I went from a 30' to a 24' .
Sure miss the extra room but the bigger one weighed 7500# empty and put #1500 on the hitch even with the torsion bars cranked tight.
Hard on my dually and it pulled like a parachute..... :evil:
Decide to get a lighter trailer and bought the 24'.[/quote]
What engine does your dually have? Part of your problem
PostPosted: Sat Jan 12, 2008 11:28 am
Just make sure your truck GVRW matches your trailer GVRW, you can give or take 1000# and it will be fine. It may bog your motor down a little on them hills, but if you have 4.10 gears, it will help a lot. It also depends on your trailer size too, not how long, but how tall. Mine is special ordered for be 12" taller to have mor
PostPosted: Sat Jan 12, 2008 11:34 am
[quote='Steve']Thats why I bought a Cummins!!![/quote]
I would love to have a Cummins!, but I found a better deal on this truck when hunting for one, I gave $31,000 for this, and it has 11,000 miles on it in 2004, so it was practically new at the time, so I saved about $15,000 on buying me a new one. :P
PostPosted: Sat Jan 12, 2008 11:48 am
It may be hard on gas, but not that hard, that why I love the power of the diesel and a manual tranny (6-speed) :P
PostPosted: Sat Jan 12, 2008 11:56 am
When I first bought the truck, I wanted to make more power out of it, so I bought an Edge Juice module with a monitor and installed it. First thing that happened is frying the clutch while doing a burnout, so I bought a f-550 dual-mass flywheel and pressure plate, and a 8-puck clutch from South Bend Clutch and changed it. It is noticably different! It will not slip now, I can take off hard and the tires will bark when shifting gears all the way to 4th gear on dry pavement, and the truck will be all over the road all the way to 6th gear on wet pavement. I loved it! I do not have the Juice on it anymore, I am going to try something different now. It ran 20-22mpg on highway with the juice, and now it is around 16-17mpg without it. :evil:
PostPosted: Sat Jan 12, 2008 3:18 pm
[quote='Steve']Ram 1500 with HEMI is rated to pull 9000 lbs[/quote]
It may be rated but I wouldn't do it.
Half ton truck and a big trailer is asking for trouble.
PostPosted: Sat Jan 12, 2008 3:25 pm
[quote='Baddvw'][quote='turboblue'][quote='The Wild Kids']I want a trailer like that, just not that long.
PostPosted: Sat Jan 12, 2008 4:37 pm
[quote='Baddvw'][quote='Roy']I think he has a Ram 1500? I don't think that would pull a 24' trailer very well. He would have to check the rating for that truck.[/quote]
I think the ram will pull it just fine, it depends on what gear ratio it has. Common size is 3.73, should have a 4.10, usually special ordered on 1500 trucks with towing packages.[/quote]
I wish it had better gearing in it, it has 3.55 which sucks. That gearing and the 4.7L (286ci) is some
PostPosted: Sat Jan 12, 2008 5:12 pm
I wish I had a deisel. My 05 2500hd chevy with 6.0L (gas) gets only about 12mpg unloaded and 11 loaded with 4.10 gears. Need more motor less gear.
PostPosted: Sat Jan 12, 2008 6:01 pm
I get 14.8 without the trailer and 14.2 with it. Seems odd but thats what it works out to be. I want to stick in a computer chip but not sure that would help me or not.
The Wild Kids
PostPosted: Sat Jan 12, 2008 7:10 pm
TWK, don't you have oversized tires on stock gears? that might be part of the issue, i run 315 75 16 on a 3/4 ton dodge, and i can tell a difference. not a huge but enough, havent towed with it yet tho. just a thought
PostPosted: Sat Jan 12, 2008 7:23 pm
Hey Wild Kids if you try to drag 9,000 pounds around the mountains with that truck you know your mileage will most likely be in the single digits. That's the bummer of a toy box. They can get heavy when they are big.:(
