It is currently Mon May 04, 2026 11:31 pm
PostPosted: Fri Jan 31, 2014 2:49 pm
Guess its time to start a build thread - for my own sake :D
File comment: Ford 2.3l Turbo Lima engine
File comment: The Lima stripped down and parted out on its way to greener pastures
File comment: Shaun at AlphaFab Industries supplied the replacement; 2.4l Ecotec, Adapter, Flywheel, Wire harness & ECU with custom flash
PostPosted: Fri Jan 31, 2014 3:11 pm
The Ford hung farther off back after being bolted to the trans, so the frame is going to need a little TLC to massage that LE5 in there. The Ecotec sitting more forward is a big plus tho, it will allows room to move the radiator behind the motor instead of blocking my rear vision since I plan on using this on the street a lot.
File comment: Shiney new parts. This baby is nice and light compared to the old iron block ford, after being stripped down it weighed 375lbs at the scrap yard
File comment: Not going to be as simple as a drop in
File comment: Touching bar - time to break out the Sawsall and operate
PostPosted: Fri Jan 31, 2014 6:27 pm
Scalpel doctor time for some cosmetic surgery. Looks good dude, must have been a tough decision for Ford man
PostPosted: Sat Feb 01, 2014 1:20 am
Be sure to take careful notes; might have to do another swap in the no so distant future ;)
PostPosted: Tue Feb 11, 2014 12:28 pm
More room is needed to mount the radiator where I want it. Would also probably be a good idea to build a new rear motor cage to better fit radiator and fan.
PostPosted: Tue Feb 11, 2014 12:34 pm
Motor now fits great with room to spare. Next on the list is chopping up all the existing mounts, sliding motor/trans as far forward as the frame horns will allow.
PostPosted: Wed Feb 12, 2014 12:53 am
Nice looking build sir!
PostPosted: Tue Apr 29, 2014 1:08 pm
Finally got some time to finish making rear trans mount over the weekend.
File comment: Made the template on PC and used construction paper to transfer to 1/4" plate.
File comment: Test fit was perfect first go around.
PostPosted: Tue Apr 29, 2014 2:17 pm
Looks like it is coming together nicely.
PostPosted: Tue Apr 29, 2014 6:07 pm
Stay strong little three rib. I believe
What was the writing on the valve cover?
PostPosted: Tue Apr 29, 2014 6:43 pm
Lol - I'm pressing my luck aren't I - you sir are paying close attention to the details. :P
...Just some writing on the valve cover from the shipper. [THUMBS UP SIGN]
Sent via TapaTalk
PostPosted: Thu May 01, 2014 1:04 pm
Finished fabricating the front trans mount using the same methods as the rear mount. 1/4" plate was overkill here but I already had it laying around. The two tabs on top are for the rear seat belts. Welding this sucker in there is going to be tight and tricky
File comment: The two tabs on top are for the rear seat belts.
File comment: Welding this sucker in there is going to be tight and tricky!
PostPosted: Fri May 02, 2014 1:07 pm
Got the front trans mount welded in there and motor/trans mounted and finally hanging on its own. Gave the motor lift a long overdue break. LOL Motor sits exactly how I want it now - on the same plane as the bars - about 3°. Dropping from 10° to 3° also relieved some of the axle angle. Underneath the pan is still higher then the trans. Couldnt be happier.
File comment: Engine sits nice and even with bars at 3° - with old mounts it was 10° and kicked way up in the air.
PostPosted: Fri May 02, 2014 1:20 pm
Oh and I picked up a 6 rib straight out of a bus from Randy - who was an awesome dude to chat with. Im blessed to have great friends like tommil77 to introduce me to his circle of buggy dudes. So ImmortalSoul219, that little 3-ribs life has been spared. :wink:
This means I need to sell my 3-rib soon which has at the very least 930 flanges (I don't believe those flanges are interchangeable with a 6 rib, is that correct???). It might have more done to it internally - but I don't know an easy way to check this without opening it up. If you do, please help me out. The 3 rib came with the buggy when I bought it and it was bolted to what I think was a non-running Ford 2.0 Lima engine.
File comment: Proud 6-rib owner now. Should be much better gearing for the 170+ hp.
PostPosted: Mon May 05, 2014 12:05 pm
I like that color.
JeffClay wrote:
-Dakotah/koko
keep on keepin' on!!
PostPosted: Mon May 05, 2014 1:37 pm
kyjr.buggy1 wrote:
I like that color.
Ha, Ill bet you do - back at ya! ;) I think its some shade of Ford Tractor Blue - how about yours?
PostPosted: Mon May 05, 2014 3:06 pm
Mine is powdercoat from Caswell platings.
-Dakotah/koko
PostPosted: Thu May 08, 2014 2:04 pm
Looking Good Jeremy!
