It is currently Mon May 04, 2026 12:59 pm
 Post subject: Bead locks and tubes
PostPosted: Wed Feb 05, 2014 6:49 pm
I am running 33" swampers that someone destroyed one of the beads on each tire. I got a set of 10" wide bead locks and plan on putting the swampers on the bead locks. I ran these tires all last year with tubes in them and my question is does any one run tubes and bead locks? Or should I skip the tubes?
 Post subject: Re: Bead locks and tubes
PostPosted: Wed Feb 05, 2014 8:15 pm
I would ditch the tubes.
PostPosted: Wed Feb 05, 2014 8:32 pm
X2
PostPosted: Thu Feb 06, 2014 12:53 pm
I run tubes in my beed locks but thats just me :wink:
PostPosted: Thu Feb 06, 2014 1:01 pm
Tubes are just extra unsprung weight. Carrie up extra tube in your toolbox that way if you do have a flat its a easy fix . I don't run tubes but always keep one in my tool box .
PostPosted: Thu Feb 06, 2014 6:58 pm
I ruined a sidewall a couple years back and put a tube in because tire was otherwise in great shape. the problem I had with tubes is when I went down to 5-7 psi I would pinch the tube in less than a days ride. Bought a new tire now because flats suck! :evil:
