It is currently Mon May 04, 2026 4:39 am
PostPosted: Thu Jan 16, 2014 10:04 pm
custom truck back frame, new seats and belts, Saco rack and pinion steering New front wheel bearings and tires new gauges switches New ignition all new wiring!!! rebuilt tranny has bus 3 rib bus to bus cvs! New stub axles with all new cvs and bearing motor is a 2054 scat 74 mm crank vz15 cam 31mm lightened lifters steel push rods mahle 94mm pistons cb performance heads 044 lightened flywheel 2100 p plate full flow block , has 2 wire alt, webber 40 carb, frame thrower distributor has rear disc's and FIRESTONE 23 degree they are cut you can contact me at 740-346-5070 cash is king 5 grand obo
PostPosted: Thu Jan 16, 2014 10:06 pm
It won't let me post images text for pics
PostPosted: Fri Jan 17, 2014 12:44 am
I'd let it go for 4 grand obo
