It is currently Sun May 03, 2026 5:39 pm
Post new topic Reply to topic  [ 85 posts ]  Go to page 1, 2, 3, 4  Next
PostPosted: Sun Sep 08, 2013 12:31 pm
I build everything suspension including front arms and spindles, wheel adapters, beams, torsion eliminators and rear trailing arms. If you need something that is not listed, all it takes is a phone call. 724-650-0816
Front combo neutral spindles $500
3" drop combo spindles $550
2.5 X 1 front trailing arms set up for either torsion springs ($450) or as a suspension shock arm. ($400)
4 X 1 front trailing arms for suspension shocks, double shear shock mounts. $500
BOTH USE THE "KING KONG" (7/8") LINK PINS
2 1/2 X 2 1/2 and 3X3 trailing arms with the "new" style bearing housings $450
Please note; I no longer offer or build a 2 x 3 trailing arm. Instead it has been changed to a 2 1/2" X 2 1/2"
Torsion Eliminators with heims $250
Front beams, heavy wall with shock towers, stock width, +2", +4", +6" starts at $300
NOT SET UP FOR TORSION SPRINGS
Prices and availability subject to change.
PostPosted: Sun Sep 08, 2013 12:43 pm
Could I use the brake rotors that are on my stock spindles? On your combos.... Don't think so but figured I would ask :)
Thanks
PostPosted: Sun Sep 08, 2013 2:18 pm
If they are kingpin rotors they will fit. Need bearings. 2 sets of combo spindles with stock hubs sitting here now have to be kingpin
PostPosted: Sun Sep 08, 2013 2:33 pm
I have the Empi KP rotors 4 bolt, like these....
PostPosted: Sun Sep 08, 2013 2:37 pm
Man that's some nice lookin stuff
PostPosted: Sun Sep 08, 2013 3:04 pm
Nice work Mike ! I have started a secret fund for some parts :twisted:
PostPosted: Sun Sep 08, 2013 3:42 pm
Mike will know more about brakes and what not . ( since he built the stuff) all I know is kinpin rotors will fit on combo spindles. And yes very great products. Mike knows what he is doin
PostPosted: Sun Sep 08, 2013 7:54 pm
I've got a set of 2x3 and 3x3 arms and they look awesome! Can't wait to get them on and running. Anytime you can get something that's been brad tested and holds up you know it's gotta be tough. Thanks mike. Chad :mrgreen:
PostPosted: Sun Sep 08, 2013 9:04 pm
how much on a beam
PostPosted: Sun Sep 08, 2013 10:51 pm
That should bolt right up to them, and if they don't, I'll make them fit. :wink:
jesse wrote:
how much on a beam
I'll know more in a day or two, I'm pricing out material.
PostPosted: Sun Sep 08, 2013 11:33 pm
ok cool i would rather buy one off you being it will be stronger and i like the choices you have in width
PostPosted: Thu Sep 12, 2013 9:59 pm
Nice looking work Mike !
PostPosted: Wed Oct 02, 2013 10:49 am
I have material to build 2", 4", or 6" over heavy wall front beams, with shock towers. No torsion springs, no rack plate. They are built to order.
I also have material to build 2 1/2" X 1" and 4" X1" heavy wall front trailing arms. They are also built to order.
PostPosted: Wed Oct 02, 2013 12:42 pm
How much for the 6 inch wider beam, trailing arms, and combo spindles? Will your arms work with springs or thru rods?
PostPosted: Wed Oct 02, 2013 12:58 pm
Give me a call, be glad to discuss it with you.
724-650-0816
PostPosted: Thu Oct 24, 2013 3:33 pm
Stumbled on this stuff in cold storage.
RCI 5 point harness, complete, excellent shape, $40 +ship
Duel spring plates, These are sold
26 5/8 long 22mm torsion bars, make offer +ship
1" hex Aluminum steering rods for stock VW, make offer + ship
724-650-0816
PostPosted: Mon Dec 30, 2013 5:07 pm
Thought I'd bump this back to the top for some awesome parts.chad :mrgreen:
PostPosted: Mon Dec 30, 2013 5:24 pm
Thanks Gasman.
Everyone check out the New Woodsbuggy store. It's in it's infancy now but there is more to come.
PostPosted: Mon Dec 30, 2013 9:28 pm
MadMike wrote:
Thanks Gasman.
Nice work! If you'd like I would love to add your products to our site! Send me a PM if interested!
-Shaun
PostPosted: Mon Dec 30, 2013 11:28 pm
Nice gesture their !
PostPosted: Thu Jan 02, 2014 11:45 am
Just ordered me a set torsion eliminators
First time I had talked to Mike he is very polite guy
PostPosted: Thu Jan 02, 2014 12:53 pm
He is very knowledgeable and a great guy.
PostPosted: Thu Jan 02, 2014 9:24 pm
Hey Mike,
I need a set of the wheel adapters. Send me a pm with the your info and I will send you the cash. Thanks
PostPosted: Thu Jan 02, 2014 10:56 pm
I need your address Mike so i can pay you
PostPosted: Thu Jan 09, 2014 11:20 pm
HOW MUCH FOR 3X3 TRAILING ARMS. DO THEY HAVE BEARINS AND SEALS IN THEM? WHAT THICKNESS IS MATERIAL USED TO MAKE THEM?
