It is currently Sun May 03, 2026 1:54 pm
 Post subject: 3 X 6 trailing arms
PostPosted: Mon Dec 30, 2013 7:21 pm
Back when I was into buggies this was the norm but now it's a rarity. Is there a reason why? My new buggy has 3x6s is why I ask...lol
 Post subject: Re: 3 X 6 trailing arms
PostPosted: Mon Dec 30, 2013 9:37 pm
Not that uncommon around here.
PostPosted: Mon Dec 30, 2013 11:47 pm
We never had anyone break an axle. I've got sway away axles and 930 joints
PostPosted: Tue Dec 31, 2013 3:33 am
That's all I ever ran on ever 2 seater I owned , those with buckshots are perfect , in fact I have a set now for sale , 4x5 arms are more stress because they are back another inch 3x6 arms were on most every buggy in fultondale & jemison back when I rode there with my 2 seater & sway away axles is not going to break !
PostPosted: Tue Dec 31, 2013 7:48 am
Yea we always ran Q or R buckshots and they seemed to work great together!
PostPosted: Tue Dec 31, 2013 10:53 am
What length axles ?
PostPosted: Tue Dec 31, 2013 11:00 am
I think 22
PostPosted: Tue Dec 31, 2013 11:11 am
I'm not sure
PostPosted: Tue Dec 31, 2013 1:38 pm
I've had 3x8's ,3x6, 3x4 and 3x2's. I'm tellin ya with all my heart, get as narrow as you can. You will see an ugly rock comin twds you and you realize you HAVE to hit it. The crowd goes, "Everybody else got up the hill, what happened to you? You will loose a lot of playing field in the narrow climb. Another issue...You will often have a different soil, rock or grip for each tire and you will always be wearing out the cut brakes. While you are wrestling your buggy, the guy in front of you goes on up to the top. Often you have to put one wheel in the grass or up high on the bank. And the NO. 1reason! With tires further out, say you have 1 tire with so-so grip and the the other grabs a no slip lip death grip. YOU WILL FISH TAIL!. I may have built some failures in my day but the best thing I ever came up was the NARROW baby chains. I don't think I ever NEED cut brakes.It's 78" wide with 14"wide tires. One other thing. Your trailing arm bushings take a beating. The WEDGE buggy is actually a 31x1 and puts the 400+lb Buick 3800 right where it needs to be. And it will beat the hell out of the rocks instead of the rocks beating the hell out of bushings and knocking me back. And it just floooaaats over them sooo gooood! Now buy my trans and tires I have posted! lol
PostPosted: Tue Dec 31, 2013 2:02 pm
I like a wider arm you can get more height with less angle and more stable sideways on a hill
PostPosted: Tue Dec 31, 2013 5:07 pm
That was truly poetic.... lol:mrgreen:
PostPosted: Wed Jan 01, 2014 7:08 am
Not sure on axle size either now , been to long ago lol , but I was thinking 21- 3/4 " or 5/8" !!! :oops: :?: :lol:
PostPosted: Wed Jan 01, 2014 12:25 pm
I'll measure them sometime... but they are big..lol
PostPosted: Wed Jan 01, 2014 6:58 pm
We've got 6x6's now, although with the mounts altered on the chassis to keep the wheel track in check (roughly 6ft6" iirc), which will be running with 30" shafts.
PostPosted: Wed Jan 01, 2014 10:52 pm
extra extra wide of a buggy may be what causes some to get side ways in the 1st place.lol my 2cts.
PostPosted: Thu Jan 02, 2014 1:08 pm
longe raxles will take alot of the stress away from the trans too. they act like springs absorbing the shock load from the tires. My race buggy has 29" axles. I think the arms I made are somthing like 9" wider and 7" longer than stock.
PostPosted: Thu Jan 02, 2014 1:48 pm
Yep, well, unless you use U-joints and splines anyway!
:shock: :o
I always thought your buggy looked fairly compact, she must be massive at the side of ours?
