It is currently Sun May 03, 2026 6:46 am
 Post subject: spark plugs for 2332
PostPosted: Fri Dec 13, 2013 4:28 pm
Which plugs do yall run for I bigger motor?
It has the big super flows if that makes a difference.
 Post subject: Re: spark plugs for 2332
PostPosted: Fri Dec 13, 2013 5:14 pm
I always ran BOSCH PLATINUM in my super flows.... ran the same plugs for 2 years just make sure the carbs are tuned correctly .
PostPosted: Fri Dec 13, 2013 7:53 pm
X2 on the Bosch
PostPosted: Fri Dec 13, 2013 8:32 pm
Any idea on heat range or plug number?
PostPosted: Fri Dec 13, 2013 9:16 pm
WR8DP .........i think this is the part number r3877 but not really sure both these numbers are on the plug
PostPosted: Fri Dec 13, 2013 10:31 pm
I run autolites. Never let me down
PostPosted: Fri Dec 13, 2013 11:18 pm
lol matt dont let that man buy them cheap sorry plugs we always run the b7es plugs i believe it is
PostPosted: Sat Dec 14, 2013 12:06 am
Lol yes I was kiddin
PostPosted: Sat Dec 14, 2013 1:03 am
i put autolights in my dads and never could make it out the shop without needing to change one :lol:
PostPosted: Sat Dec 14, 2013 11:00 am
Now that's the truth ......i put a set in my buggy becouse i could not get a set of good plugs took it a 1/2 hour before it would fire on all 4 .....
PostPosted: Sat Dec 14, 2013 3:26 pm
All oriellys had was ngk so I bought them for now just to see if itll fire on all 4..
PostPosted: Sat Dec 14, 2013 3:40 pm
Yea that's what I run the parts store around me have to order Bosch that's what I've always ran
PostPosted: Sat Dec 14, 2013 4:50 pm
Ngk is all you should run that's the ones I was talking about
PostPosted: Sat Dec 14, 2013 5:19 pm
Well cool! I should be good then.
PostPosted: Sat Dec 14, 2013 8:23 pm
NGK plugs work fine in big air cooled motors.
PostPosted: Sat Dec 14, 2013 8:28 pm
Im hoping its plugs. I checked my carbs but its not firing as hot on 1 and 2 for some reason. And the occasionall pop at idle
PostPosted: Sat Dec 14, 2013 8:41 pm
Check for vacuume leaks and exhaust leaks for popping. I always ran Bosch W8 long reach plugs, Bosch wires and a Bosch blue coil with pentropics electronic ignition never an issue and a orange German cap and rotor. Just can't beat the factory setup for reliability
PostPosted: Sat Dec 14, 2013 8:47 pm
I had the distributorless ignition on my other buggy. It worked grest but dont see them for sale anywhere now
PostPosted: Sun Dec 15, 2013 12:13 am
Check your carburetors make sure they are in sync I gotta feeling you got one that is out. The side that is running a little cooler open your idle screw a little bit . Then recheck with a heat gun see what happens popping will probably go away also
PostPosted: Sun Dec 15, 2013 12:25 am
Im going to keith Mitchells here in a few days and get a new exhaust ..this one is all rust and put all new gaskets as these are leaking.. so that may be the problem or atleast one of them!! Gonna buy a sync tool also for the carbs. I can put my hand over the venturies on the drivers side and it doesn't seem to change the way it idles.. now 3 and 4 it will almost kill it.
Considering it hasnt been really ran much in a few years im looking to to clean a few cobwebs out..lol
PostPosted: Sun Dec 15, 2013 1:37 am
Check your intake gaskets sounds like a sign of an intake leak if the rpms pick up
PostPosted: Sun Dec 15, 2013 3:17 am
Will do! Thanks for all the help fellas! Gotta get her going so I can come out and play..lol
Users browsing this forum: Majestic-12 [Bot] and 0 guests
