It is currently Mon May 04, 2026 2:25 pm
PostPosted: Tue Nov 26, 2013 6:09 pm
We ride a lot of loose coal and shale and I just picked up a set of 33x14.50 boggers I'm wondering how they do
PostPosted: Tue Nov 26, 2013 6:18 pm
My guess is if you put them on and run it, you'll find your answer.. :wink:
PostPosted: Tue Nov 26, 2013 6:32 pm
Cut the shit outta them and they hook good
PostPosted: Wed Nov 27, 2013 6:19 am
What's a good way to cut them if you don't have a groover
PostPosted: Wed Nov 27, 2013 7:20 am
Sawzall. Sharpen the blade like a knife. It will cut really easy. May have to resharpen it a couple times before your finished.
PostPosted: Wed Nov 27, 2013 9:26 am
1 1/2 Stanley wood chisel (a new one) , lay the tire flat on ground and apply little pressure . Needs to be a Stanley IMO
PostPosted: Wed Nov 27, 2013 1:35 pm
With the sawzaw do you need coolant and when using wood chisel do you need heat
PostPosted: Wed Nov 27, 2013 1:56 pm
Nothin on the blade. It cuts like butter so be careful and don't ruin a tire. It cuts so easy that is won't take a sec to get in a hurry and phsssss
PostPosted: Wed Nov 27, 2013 10:14 pm
No need for heat. I couldn't believe it my self till I tried it. If on rims and air up is easiest. I've done 2 sets off boggers with one chisel. Even a older man tried it and couldn't believe it. He went home and groves his tsl swampers . Only take 20 min a tire at most
PostPosted: Thu Nov 28, 2013 6:20 am
We'll I know what I'll be doing tonight thanks for all for your input
PostPosted: Thu Nov 28, 2013 7:17 pm
Wow that was a bitch but I got them done they look ok but I need a groover now
PostPosted: Thu Nov 28, 2013 8:27 pm
Let's see a pic
PostPosted: Thu Nov 28, 2013 10:35 pm
http://daymotorsports.com/proddisp.php? ... of+%234+bl get the #12 blades and head
PostPosted: Fri Nov 29, 2013 12:54 am
Stanley style ??
PostPosted: Fri Nov 29, 2013 10:34 am
Yeah the cuts aren't the best I'm still a novice at this
PostPosted: Fri Nov 29, 2013 10:35 am
And I tryed to find Stanley all I could find was Sheffield wood chisel
PostPosted: Fri Nov 29, 2013 10:52 am
Oh ok. I've tried several kinds, Stanley for some reason cuts better. Good job
PostPosted: Fri Nov 29, 2013 8:47 pm
Yeah they definitely look a lot more bald now
PostPosted: Sat Nov 30, 2013 10:03 pm
Great Job. Did you heat the chisel or just push it through?
PostPosted: Sat Nov 30, 2013 11:33 pm
With a Stanley and tire mounted on wheel u just push easy. Wait till u try a Stanley , I'll post pic of the Stanley tommorrow .lol
PostPosted: Sun Dec 01, 2013 10:33 am
I gotta find some new axles before I'm up running again but I can't wait to try them boggers
