It is currently Mon May 04, 2026 12:38 pm
 Post subject: brake line plumbing
PostPosted: Wed Nov 27, 2013 9:19 pm
going to put front disks on and wanted some ideas of how lines are ran....i have a big bore single outlet master cylinder and want to run porportion valve on fronts....?????so, one line to a 2 outlet junction....out of junction run one line to rear, one line to front porportion valve....out of valve to each front caliper???
 Post subject: Re: brake line plumbing
PostPosted: Wed Nov 27, 2013 9:24 pm
what valve are you using.and what calapers are you using on the front and back.
PostPosted: Thu Nov 28, 2013 4:30 pm
front is the wide 5 king pin disk setup...rears (for now) are ghia.....porportion valve is from appletree single inlet and outlet
PostPosted: Thu Nov 28, 2013 5:21 pm
http://www.appletreeauto.com/DISC-BRAKE ... 22-2880-0/ was going with this kit and using my cnc master cylinder....
PostPosted: Thu Nov 28, 2013 5:23 pm
http://www.appletreeauto.com/BRAKE-PROP ... -AC611585/ and a valve like this one.....both are on sale til dec 2nd......then i guess a rear upgrade to an s10 style caliper?????
PostPosted: Thu Nov 28, 2013 5:32 pm
I used to run the adjustable proportioning valve with the handle on it. And from adjusting the pressure, I never really found that there was much of a difference on my buggy. I use wellwood 4 pistion calibers in the back. In the front, I use 2 piston wellwood calibers. 2 years ago, I ended up taking the proportioning valve off. Because it just rusted in place and was not working anymore. What I found was the difference in the size of the calibers being the big one in the back that has more stopping power. The little ones up front that has less stopping power was worked out really well. If you size your calibers right, you will not need the proportioning valve. So what you outta do, is put the ghia calipers up front, and get some four piston or bigger for the back and you will be set.
PostPosted: Thu Nov 28, 2013 10:29 pm
the main reason why i was trying not to run the ghias on front is because i have a king pin front beam and that kit uses an empi conversion bearing for king pin front ends...and i would have to buy 4 lug rims.....
PostPosted: Fri Nov 29, 2013 9:21 am
Ive got one of those adjustable proportioning valves also. I dont think it ever makes any difference that i can tell.
PostPosted: Sat Nov 30, 2013 12:06 am
ok change of plans...tranny went out in work van so funds have been depleted.......going with the el cheepo front ghia brakes...no porportion valve if i hate them ill put s10 brakes on back
