It is currently Sun May 03, 2026 6:24 pm
PostPosted: Tue Nov 26, 2013 10:36 pm
Ok im getting ready to do a thru all front end on my buggy and I have combo spindles with it will these rims work with what I have ?
PostPosted: Wed Nov 27, 2013 8:07 pm
someone on here has to know something lol
PostPosted: Wed Nov 27, 2013 8:19 pm
Your rim will have to have the same bearings as your spindle needs. What are the rims off of,B/J or K/P? Need a little more info to try and help you out. Chad :mrgreen:
PostPosted: Wed Nov 27, 2013 8:43 pm
I took them off my king pin and they have no races in them I pressed them out to use for my hubs
PostPosted: Wed Nov 27, 2013 9:17 pm
you cant run front breaks with those rims . if you run wellsville you need breaks. lets see some pic of the frontend your using.
PostPosted: Wed Nov 27, 2013 9:25 pm
i've been running wellsville for years with all my buggys i live 20 mins from there - never had back brakes on a buggy ever - the front end is king pin i'l have to get some pics tomarro and post them of the set up - i have a 6inch wider warrior beam now thats shot- kingpin and the thru all front end is king pin also
PostPosted: Wed Nov 27, 2013 9:26 pm
oh and the thru all front end is 6 inches wider also
PostPosted: Wed Nov 27, 2013 9:55 pm
No rear brakes???
PostPosted: Wed Nov 27, 2013 10:11 pm
I have rears just never had front brakes
PostPosted: Wed Nov 27, 2013 10:29 pm
ok heres the wore out front end on her now
PostPosted: Wed Nov 27, 2013 10:30 pm
its pretty bad
PostPosted: Wed Nov 27, 2013 10:38 pm
heres the other front end gotta put the longer arms on still
PostPosted: Wed Nov 27, 2013 10:39 pm
and the combo spindles
PostPosted: Wed Nov 27, 2013 10:44 pm
Ok sorry good looking spindle. Good luck
PostPosted: Fri Nov 29, 2013 12:21 pm
can anyone make anything out of what i posted ?- i'd really like to know so i can buy the rims !!
PostPosted: Fri Nov 29, 2013 4:47 pm
I'm sure you can make them work. You will have to replace the insides since there not there so you should be able to buy what you need to make them fit. Chad :mrgreen:
