It is currently Sun May 03, 2026 6:47 am
PostPosted: Tue Nov 12, 2013 11:22 pm
Ok i have a 2110 and i am running MSD 6AL digital and a pro billet distributor. i am not sure how i would go about setting static time. I need to do this because i got a new set of carbs and messed with the timing for no good reason when i took the old ones off :mrgreen: dumbass me!!!!
now i can not seem to get the motor to idle long enough to set my best lean idle.
PostPosted: Wed Nov 13, 2013 12:14 am
im pretty sure msd has a help hotline...if you dont get the answer you need here
PostPosted: Wed Nov 13, 2013 1:03 am
Point rotor at #1 wire. Point 7.5 btdc at case seam. loosen dist. connect 1 wire type test lite to neg side of coil and stick test lite into a spring on the carb for a ground. Turn key on. Rotate dist cw til lite goes out then counter cw til lite turns on. tighten dist. Remove wrench from pulley. If you have a 2 wire test lite then connect them to the coil. Red + black neg . Stick the test lite in the spring. Rotate dist the same way but instead the lite will go from green to bright green with a 2 wire test lite.
PostPosted: Thu Nov 14, 2013 9:52 am
Ok i got it running last night its back to being a ripper again.
Now for the next question where the hell do you mount the return spring on these carbs on my old set there was a piece that hung down that had a hole in it to mount the spring but these are cast and do not have a place to put it. both sides of the carbs look the same.
This is what my old set looked like this set did not come with this.
PostPosted: Thu Nov 14, 2013 10:57 am
I just noticed your little red arrow8-) never considered that,nor tried it, and dont know if id trust it not to break that brass piece!! Darrell has his screwed to the frame with different springs.seems to work. I think the correct answer is riggernig it:roll::grin::D:-D
PostPosted: Thu Nov 14, 2013 11:45 am
I made some small aluminum brackets thats held down by the mounting stud
PostPosted: Thu Nov 14, 2013 11:51 am
I just ran a spring from the hex bar where the throttle cable hooks up to my exhaust pipe where the spring go on the collector good luck
PostPosted: Fri Nov 15, 2013 11:26 pm
I just hooked the spring to the bottom filter mount.
PostPosted: Sat Nov 16, 2013 10:39 am
I did something like Rick did . Works good
