It is currently Mon May 04, 2026 6:40 am
 Post subject: Rear air bag set UP!?
PostPosted: Wed Nov 06, 2013 7:55 pm
Need help setting up air bags and what bags to buy pics and links would be great thanks so much!!
PostPosted: Wed Nov 06, 2013 8:23 pm
You go to bagit.com look for by 2 get 2 and look for 3800 bag
PostPosted: Wed Nov 06, 2013 8:25 pm
Airbagit.com sorry
PostPosted: Wed Nov 06, 2013 8:26 pm
PostPosted: Wed Nov 06, 2013 8:28 pm
Madmike is very smart when it comes to it. He helped me with it not in person tho
And lpb and buggybarn
PostPosted: Wed Nov 06, 2013 8:45 pm
Image in the pic it looks like the bags attach to the bar under the fuel tank....there is actually a thick wall tube behind that one that the top of the bags mount to...and a 3 point mount on trailing arm
PostPosted: Wed Nov 06, 2013 8:50 pm
I was looking at yours^^ to go by reference I've been looking on air bag it now with air bags mounting then in the right angle is a must?
PostPosted: Wed Nov 06, 2013 8:55 pm
Other thing do you have to run torsion eliminates?
PostPosted: Wed Nov 06, 2013 10:02 pm
idk why there sideways but that's how me and my brother did mine and yes u have to run torsion eliminators that's a must danspermorfanceparts has what you need I think 150 for them plus shipping maybe a couple dollars more
*subiepower*
PostPosted: Wed Nov 06, 2013 10:07 pm
when we mounted mine we bolted and made sure to cycle through your travel to make sure it looked all right we didn't have no degree finder or anything like that but seems to ride nice for the hour I had on it if you have the know how u could do some real nice set up like I think mad mikes he has swivels and everything on his looks real nice and neat
*subiepower*
PostPosted: Thu Nov 07, 2013 8:29 am
you can get away with taking your bars out and just run the spring plate for a while too.
PostPosted: Thu Nov 07, 2013 9:29 am
Got any pics of air lines and how you did them?
PostPosted: Thu Nov 07, 2013 8:44 pm
I got fittings to put just a valve stem on there. But you can run air lines if that's what your dreaming up. I just. K.I.s.s. it
PostPosted: Fri Nov 08, 2013 9:56 am
If you put a pump onboard you have to run one way checkballs before each bag, otherwise when the pressure increases in one bag it affects the other.
PostPosted: Fri Nov 08, 2013 10:02 am
Here is a crude diagram that may help
PostPosted: Fri Nov 08, 2013 10:03 am
Sorry schrader valve
PostPosted: Thu Nov 21, 2013 9:52 pm
I'll probably just do valve stems
PostPosted: Fri Nov 22, 2013 5:40 am
valve stems are simple and easy....if im riding somewhere rough and doing a lot of climbing i run them soft at 50 psi if i need ground clearance or trail riding i run up around 60 psi....took about 2 or 3 trip to figure out what felt the best now i can set them and forget em
PostPosted: Wed Nov 27, 2013 11:43 am
Really that much air in them are you running a vw engine
PostPosted: Wed Nov 27, 2013 1:49 pm
My air bag with valve stem set up on 8x5 arm built by buggybarn(aka nick) but lpb on bag mount
PostPosted: Thu Nov 28, 2013 2:45 pm
What did those arms run you? I like then!!
PostPosted: Tue Feb 11, 2014 8:41 pm
would a rancho 9000 with 12 inch travel be a good shock for a bag setup
PostPosted: Tue Feb 11, 2014 8:52 pm
ive been running the ranchos that are for chevy pickup/ k5 blazer with 3 inch lift
PostPosted: Tue Feb 11, 2014 9:53 pm
All I know for climbing rough stuff is fast impact, slow return. I have those shocks on both my w/c's.
