It is currently Mon May 04, 2026 10:00 pm
 Post subject: I NEED A 542 RING
PostPosted: Tue Jan 08, 2008 7:10 pm
Any body have a ring?
PostPosted: Tue Jan 08, 2008 7:53 pm
Weddle sells them (new and used I think)..not cheap, though..
PostPosted: Tue Jan 08, 2008 11:57 pm
What does the 542 come in? Is it an aftermarket gear? I know 3, 5, and 6 rib trannys come with different ratios but what does the 542 gear come in?
PostPosted: Wed Jan 09, 2008 9:02 am
Came in a 3 rib. Was not a very common ratio and pretty rare. Must have the matching pinion shaft to go with it.
It is the weakest ring gear out of all of them.
PostPosted: Wed Jan 09, 2008 9:12 am
a vanagon diesel came with a 5.42 ring an pinion in a 002 case but it was a 091 size they also made a 5.42 small 002 they weren't strong you don't want that one
PostPosted: Wed Jan 09, 2008 9:16 am
Now that's good information. Did not know that.
PostPosted: Wed Jan 09, 2008 1:04 pm
According to Weddle, The 5.42 is supposed to stronger then the 5.38.
PostPosted: Wed Jan 09, 2008 1:13 pm
[quote='Eric DeBord']According to Weddle, The 5.42 is supposed to stronger then the 5.38.[/quote]
I've heard that too.
Must have another tooth on the pinion shaft.........
PostPosted: Wed Jan 09, 2008 5:46 pm
Is the pinion shaft from this diesel transaxle the same as a regular 091, 4.56 pinion shaft? If not, what does it take to make it work?
How does the diesel 5.46 R&P compare in strength to the 4.56 091?
SORRY STEVE, did not mean to hijack your thread!
PostPosted: Wed Jan 09, 2008 7:28 pm
a 5.42 was in the 82 or 83 diesel vanagon they are one strong ring and pinion,weddle has a 5.42 aluminum case brand new 6 rib not side shift (brand new)it has all the 6 rib gears but a 5.42 for 1500.00 dollars all u have to do is change the bellhouse and pilot shaft
PostPosted: Wed Jan 09, 2008 7:39 pm
diesel vanagons also had a 5.86 they are very weak the pinion is really small
PostPosted: Wed Jan 09, 2008 7:42 pm
[quote='Roy'][quote='Eric DeBord']According to Weddle, The 5.42 is supposed to stronger then the 5.38.[/quote]
SORRY STEVE, did not mean to hijack your thread![/quote]
the diesel pinion shaft is the same as an 091
PostPosted: Wed Jan 09, 2008 7:51 pm
You didnt hijack anything, theres alot of good info here. My six rib has 542, but one tooth has a crack in it. I cant seem to find one.
PostPosted: Wed Jan 09, 2008 7:53 pm
[quote="Steve"]You didnt hijack anything, theres alot of good info here. My six rib has 542, but one tooth has a crack in it. I cant seem to find one.[/quote
steve u will have to find both r&p they have to match or it will vibrate so bad u couldnt drive ur buggy
PostPosted: Wed Jan 09, 2008 7:55 pm
Got one? A set that is.
PostPosted: Wed Jan 09, 2008 7:58 pm
i got 2 full side shift trannys 5.42 but they aint 4 sell i think i got 1 5.86 side shift that would b 4 sell,weddle has the 542 r & p but they are expensive
PostPosted: Wed Jan 09, 2008 8:18 pm
how much
PostPosted: Wed Jan 09, 2008 8:25 pm
got 2 pull outs will take 1000.00 for both plus shipping
PostPosted: Sun Jan 13, 2008 4:30 am
[quote='rockrockets1']a vanagon diesel came with a 5.42 ring an pinion in a 002 case but it was a 091 size they also made a 5.42 small 002 they weren't strong you don't want that one[/quote]
The 2 vanagon diesels I parted out have 5.86 r&p in them,,,,cant remember years but there are 002's what part is 091 size?
