It is currently Sun May 03, 2026 6:18 pm
PostPosted: Sat Nov 02, 2013 9:31 pm
Just Bought a 1963 Volkswagen two seat rail buggy, has 1200 VW Engine on it. Has CNC Single lever brake, Two 4-point harnesses. The bad, Engine seized, rear wheel cylinders leaking bad, Tires are brand new (but at least 8 years old), starter doesn't turn. needs battery, air cleaner, and possibly many other things. Front shock tower on driver's side is rotting out and all boots are dry rotted. but the rest of the buggy is solid. no title. Was it worth $800
PostPosted: Sat Nov 02, 2013 9:35 pm
Seems like a fair price for a complete buggy. Post some pics to get a better idea what your dealing with.
PostPosted: Sat Nov 02, 2013 9:47 pm
i will take some pics and post tomorrow. Any ideas on how to repair the shock tower? it's a ball joint front end
PostPosted: Sat Nov 02, 2013 10:14 pm
Not sure of your Fab skills or equipment but I cut mine out rebraced the beam and made new shock towers
PostPosted: Sat Nov 02, 2013 10:17 pm
PostPosted: Sat Nov 02, 2013 10:22 pm
Your front end looks a little different than mine. I was going to add supports to it, but it is thin metal and curved. Will probably end up cutting it off and making my own.
PostPosted: Sat Nov 02, 2013 10:24 pm
I'd say you got your moneys worth. Get that thing running and beat it.
PostPosted: Sat Nov 02, 2013 10:27 pm
Hopefully the 50 year old engine doesn't grenade on my first run. Lol. Thanks pal. Was having second thoughts about buying the thing. Glad I came here. :)
PostPosted: Sat Nov 02, 2013 10:40 pm
Put your location in your profile. People will come crawling out of the wood work willing to help you. This is a great site full of great people.
PostPosted: Sat Nov 02, 2013 11:15 pm
just realized that you're in columbus. only about 2 and a half hours from me. any tips on how to haul the thing. Don't have money for a trailer at the moment. i saw pics online that have some kind of hitch bar attached to the front of the buggy, but figured that would make some excessive wear on tires pulling it like that.
PostPosted: Sun Nov 03, 2013 12:29 am
Your only hr and a half from me and close to wellsville :mrgreen: get that buggy ready and head on up
PostPosted: Sun Nov 03, 2013 9:14 am
So close to wellsville you lucky dog
PostPosted: Sun Nov 03, 2013 9:44 am
Cost anything to get into wellsville?
Got a feeling it could be an expensive trip. Lol. First hard ride is guaranteed to break something on my 50 year old machine.
PostPosted: Sun Nov 03, 2013 1:00 pm
The tins are missing off the cylinders. If you don't have them you need to find them cause it won't last long without.
Shepard0001 wrote:
PostPosted: Sun Nov 03, 2013 1:07 pm
Wellsville is free to ride . Better to go with a group or at least have someone that knows it good. Wellsville is hard on good equipment. :mrgreen:
PostPosted: Sun Nov 03, 2013 4:26 pm
I have to disagree on "free to ride" part Dave, even if I drive back onto the trailer, the weekend there still cost me several brain cells and a damaged liver. :lol:
Fixed the last part, "Wellsville is hard on even the best of equipment." The guaranteed best way not to break stuff when you go to Wellsville, is to leave it on the trailer.
Besides do we break stuff or do we just find the weak spots?
PostPosted: Sun Nov 03, 2013 5:14 pm
Hard on ankles too lol. I have not had any problems riding there but I bend my rims on the rear more and more
PostPosted: Sun Nov 03, 2013 7:30 pm
The drive line "might" be 50 years old but that chassis isn't. Looks like a little TLC and you'll have something to work with. Lots 'o luck.
PostPosted: Sun Nov 03, 2013 8:04 pm
I have the upper tins, had to trim them today to make them fit. got a steering brake issue, changed wheel cylinders,then bled out my brakes. have really good pressure on brake pedal, but when i push the lever forward, the pressure leaks off. Was reading online that you have to ride and re-bleed them for it to be correct. put on plastic pushrod tubes (using these to test engine). If she doesn't explode, i'll change all the base and head gaskets, install new pushrod tubes, then start on accessories. If she does blow, might be parting it out.
