It is currently Tue May 05, 2026 12:54 am
 Post subject: 5 rib questions
PostPosted: Mon Oct 28, 2013 11:20 am
What setup would work with a 5 rib trans? I haven't seen any reviews on the 5 rib, all i've heard is 3 rib or 6 rib. Just considering the 5 rib as an option if I can't get a 3 or 6 rib trans.
 Post subject: Re: 5 rib questions
PostPosted: Mon Oct 28, 2013 2:10 pm
3 rib are close to the same
3 and 5
PostPosted: Mon Oct 28, 2013 2:36 pm
I love a 5 rib with a1835
PostPosted: Mon Oct 28, 2013 4:34 pm
I am considering using a 5 rib with an 1835cc or 1915cc setup.
PostPosted: Mon Oct 28, 2013 9:48 pm
The 5-rib has a lot more wheel speed most have a 4:86 gear. A 3-rib has a 5:38 or a 48 so it takes more power to run a 5-rib and the 5-rib is a lot stronger trans. Most people with a 1915 like em.Nothing the same about the 3 and 5 tho
PostPosted: Tue Oct 29, 2013 10:34 am
Is there any difference between the 5 rib and 6 rib? Would a 5 rib work in a 1835cc setup?
PostPosted: Tue Oct 29, 2013 2:15 pm
3 and 5 rib have the same 1-4th gears.. difference is the ring and pinion..4.86 for the 5 rib and 5.38 in the 3 rib. I would suggest the 5 rib, because the extra speed helps on longer hills. A 6 rib is a lil much for anything less than a stroker in my opinion. A 5 rib has a stronger r-p than the 3 rib, but all other internals are the same..
LEGALIZE BLUEGRASS!!!
Save a tree... eat a Beaver
PostPosted: Tue Oct 29, 2013 8:40 pm
Thanks for your input
PostPosted: Thu Oct 31, 2013 1:22 am
I ran a y rib with a 1641 garage floor motor. Ran just fine. I went from bug tyranny. To 6 rib didn't really see a difference. 6 rib is a better tranny
PostPosted: Sat Nov 09, 2013 10:38 pm
I use a 5 rib in my buggy. I have a 1915 with dual carbs and I run 31" cut Firestones. It's the prefect combination for my horsepower and tire size. I love it.
cron
