It is currently Sun May 03, 2026 6:48 am
PostPosted: Sun Oct 27, 2013 7:59 pm
I am currently thinking about building a two seater buggy and I like to do hills, jumps, and wheelies. I am going to use a sandfox frame but I'm not sure whether I should go with a 1641cc VW engine with a scat cam or a 1915cc engine with dual carbs, also with a scat cam. I am fairly new to the VW engines and would appreciate any information. I am new to the forums and would like to learn more about VW buggies.
PostPosted: Sun Oct 27, 2013 8:10 pm
go with a 1915, this will let you climb about any hill that you want and still work well on the trail.
i currently have a 1641 and you just don't have the recovery on a hill if you need it.
so that's why i am going to go with at least 1915 my self wither it be running duals or a single carb.
PostPosted: Sun Oct 27, 2013 8:41 pm
What about an 1835cc or 1776cc? Just wondering because I've also looked into those 2 sizes as well. I ride most in Trevorton and St.Clair, don't know if that would be a factor in what size engine to select.
PostPosted: Sun Oct 27, 2013 8:58 pm
bigger is better 1915 is a good one i ran one for years. what transmission are you running.
PostPosted: Sun Oct 27, 2013 9:05 pm
Wheelies in a buggy? With 1915:)
I am not sure of your situation and funds or fabricating skills but I would suggest buying a Buggy that has already been built rather than building a new one.
As for engines, I would suggest an 1835 or go all the way to a 2276. Remember, most power comes more cost. Not only in the engine but the Transmission, CV Joints, Axles, Etc....
An 1835 with a 3 rib trans is a reliable setup and works perfectly with tractor tires or small boggers.
PostPosted: Sun Oct 27, 2013 9:09 pm
afterburnt: I am planning to run a 3 rib but am also considering a 6 rib.
PostPosted: Sun Oct 27, 2013 9:13 pm
I am getting some help with fabricating skills from my dad and my brother. They have buggies and I am saving up money to buy a sandfox frame. I have other funds for the engine, trans, tires and wheels, etc.
PostPosted: Sun Oct 27, 2013 9:14 pm
Now with the 1835cc with a 3 rib setup, does the 3 rib have to be modified or can I leave it stock? or does that depend on my riding style?
PostPosted: Sun Oct 27, 2013 10:15 pm
echo-tech??? cheap and powerful. There I said it :evil: :evil: :evil: :mrgreen: :mrgreen: :P :P :P
PostPosted: Sun Oct 27, 2013 10:40 pm
I was running a 1600 with a 3 rib with no issue but now I'm running a 2276 with a 6 rib with out a issue yet and like Mickey Mouse said bigger u go to bigger ur pockets
PostPosted: Mon Oct 28, 2013 6:48 am
I ran an 1835 for years with a stock 3 rib and did not have any issues. However, driving style can break anything and everything. You still need to pay attention to what you are doing..
PostPosted: Mon Oct 28, 2013 7:05 am
Ecotec ya no more tuning carbs cleaning jets and listening to lifters tap! For half the money you spend on VW aftermarket cranks rods cams and heads you can do a Ecotec that was the best investment I ever did to my buggy.
PostPosted: Mon Oct 28, 2013 11:15 am
thank you guys for all of the input. I will look into the 1835cc with a 3 rib setup and i'll also check out the 2276cc with a 6 rib setup. Like i said before, I am new to VW buggies and am treating the build like a learning process.
