It is currently Tue May 05, 2026 4:49 am
 Post subject: Crank seal leaking badly
PostPosted: Sun Oct 27, 2013 12:39 pm
How difficult is changing out the crank seal? My 1915 is leaking very badly to the point the pad I had under to catch the oil overflowed.
Thanks need to get this fixed soon.
Flipper
The Wild Kids
PostPosted: Sun Oct 27, 2013 5:29 pm
if its the rear seal then you have to pull the motor and take the fly wheel off. its not hard and when you have the fly wheel off change the O ring that seals the fly wheel to the crankshaft .
PostPosted: Sun Oct 27, 2013 7:27 pm
If your crank seal is leaking badly I'd check your end play before doing anything
PostPosted: Sun Oct 27, 2013 7:43 pm
just a reminder. a pulley will blow out oil if your breather box is stopped up or some other ventilation problem like kinky hose. bad ventilation and way too too much oil can blow the flywheel seal out.
PostPosted: Sun Oct 27, 2013 7:58 pm
the penguin got some ice cream while waiting on the mechanic to diagnose his transmission. With his short flappy arms , he spilled it all over himself. The mechanic looked up and said , sir ,it looks like you've blown a seal.
PostPosted: Sun Oct 27, 2013 11:36 pm
:P :lol: :P :roll:
PostPosted: Mon Oct 28, 2013 6:58 am
Are you leaking from the pulley? Mine was always leaking like crazy until I replaced the pulley with a Sand Seal Pulley. That fixed the problem.
