It is currently Tue May 05, 2026 2:01 am
 Post subject: CARB RUNNING LIKE S$&@
PostPosted: Sun Oct 13, 2013 2:58 pm
So I clean the carb and it's a webber 40 idf Italy made I clean it with cleaner tear it apart clean it put it back on runs awesome till your in the woods bouncing around than it won't idle but get in the gas and it rips I can't figure it out! That's guys!
PostPosted: Sun Oct 13, 2013 4:04 pm
Prolly need to set the float level for off road application
PostPosted: Sun Oct 13, 2013 4:47 pm
wish i could help but it sounds like mine mine idles ok just have to tac it up to go and like you said as long as ya got your foot into it it will rip.i did adjust the aclerator pump helped some.
PostPosted: Sun Oct 13, 2013 7:36 pm
Shake the back of your buggy hard when it is sitting there idling if the idle drops adjust the float I think mine is set at 13-15 mm closed leaving the gasket on measure it at the end of the float closest to the center of the carb
PostPosted: Sun Oct 13, 2013 8:10 pm
I set mine at 11mm seems to work good.
PostPosted: Mon Oct 14, 2013 3:27 pm
Float looks great.. it's about 14mm
Its acting like the idle jets are dirty but I pull them or and clean I choke it out seems to run ok for a few than boom only running on 1 and 4 again. It's starting to piss me off lol
PostPosted: Mon Oct 14, 2013 10:31 pm
Blow some carb cleaner and air through the idle circuit.
PostPosted: Tue Oct 15, 2013 11:55 am
If it runs good till its bouncing around in the woods float is to high
PostPosted: Tue Oct 15, 2013 6:06 pm
x2
PostPosted: Wed Oct 16, 2013 7:33 pm
Still doing after 3 cans lol going to hit it a few times with my 6 pound hand slammer lol
PostPosted: Thu Oct 17, 2013 12:18 pm
You check fuel pressure? Is float still 14mm? Does it still run fine of flat smooth surface?
PostPosted: Thu Oct 17, 2013 5:01 pm
mine was running funny so carb was the first thing i suspected was problem...banged my head aftr cleaning and tuning....turned out to be a bad plug wire....
PostPosted: Thu Oct 17, 2013 7:48 pm
Never thought to check my plugs its running great when it is wild open I put platinum Bosch plugs in it that's probably problem!
PostPosted: Thu Oct 17, 2013 9:40 pm
Does it quit idling after you go through puddles or just anytime riding through the woods my plug wires were seeking all over on my one motor making it idle very rough only way I knew that was by checking it at night and that's when I noticed a light show going on from my plug wires after they dried out it ran fine till the next time I hit a puddle
PostPosted: Thu Oct 17, 2013 9:53 pm
When you do have a bad plug wire , pull the end off of it and snip an inch off and re twist into it b4 you go buy new ones.
PostPosted: Fri Oct 18, 2013 5:28 am
Yea I swapped the wires out when it started doing it
PostPosted: Fri Oct 18, 2013 6:02 pm
Carb was cracked!
cron
