It is currently Tue May 05, 2026 12:49 am
 Post subject: 6 rib what to do?
PostPosted: Tue Oct 01, 2013 1:13 am
this is third 6 rib thinking all similar problem havent tore into other ones what should i do to fix and prevent from happning again tranny are getting expensive looking for long term fix
sorry in advanced for pic better ones can be seen on photobucket
http://s168.photobucket.com/user/zelien ... t=3&page=1
*subiepower*
 Post subject: Re: 6 rib what to do?
PostPosted: Tue Oct 01, 2013 9:50 am
German Suuuuppppeeerrrr Diff :evil: :mrgreen: :roll:
PostPosted: Tue Oct 01, 2013 10:10 am
german :!: .not a floaty :? super diff. :!: chromemoly side cover
PostPosted: Tue Oct 01, 2013 2:06 pm
Ya exactly what lpb said ! And chromoly side cover . I had a china diff they are junk junk. Junk blew a side screw out of my 6 rib when diff broke ruined everything . 3 hrs of mild riding on tranny .
PostPosted: Tue Oct 01, 2013 10:41 pm
now where to get one and is that the only thing i should do the actuall gears dont look bad but idk i am running a stock subaru to
*subiepower*
PostPosted: Thu Oct 03, 2013 11:19 am
Problem solved:
PostPosted: Thu Oct 03, 2013 12:49 pm
PhillipM wrote:
Problem solved:
What is that?
PostPosted: Thu Oct 03, 2013 3:27 pm
aboone993 wrote:
PhillipM wrote:
Problem solved:
What is that?
X2
PostPosted: Thu Oct 03, 2013 5:32 pm
x3 come on phillip fill us in!!!
PostPosted: Thu Oct 03, 2013 7:50 pm
I believe it is a Renault UN5 transaxle out of a van they only have across the pond.
PhillipM wrote:
shadetree wrote:
Wow! The boys at East lynn in WV would love this ride. What is the drivetrain in this machine?
PhillipM wrote:
From a Renault Master commercial van.
RX8 engine + UN5 gearbox.
PostPosted: Thu Oct 03, 2013 8:01 pm
Question is will it fit in a plastic tote with some pillows?
PostPosted: Thu Oct 03, 2013 9:16 pm
Haha
PostPosted: Fri Oct 04, 2013 12:03 am
i dont know much when it comes to building a trans but if this keeps going on maybe something is not in line right or shimmed correctly or something along them lines
PostPosted: Fri Oct 04, 2013 12:21 am
Lay off the cut brakes til ya get a German 4 diff. And if ya have enough power and ya keep on cut braking doing donuts, your case will crack. Who said that? I said that. Been there , done that several times. lol
PostPosted: Fri Oct 04, 2013 9:06 am
Someone must have fetched a container full of them over there not long back because I know there's a guy building a Honda powered sand racer over there with one in. The nose is a little longer than the VW but otherwise it pretty much slides in. If you have a long arse on your buggy the long nose won't be an issue, if it is, hook it over the top of the beam.
PostPosted: Fri Oct 04, 2013 9:21 am
as far a shims go how much play is suppose tobe in there cause i have had a lil more then i think you want thats what i was thinking that my axles are sucking them out and causeing them to spin then break but idk ?
*subiepower*
PostPosted: Fri Oct 04, 2013 9:25 am
i do use cutting breaks a good bit never thought that would be a problem and if i get the diffs with the 4 spider gears everything will be better and is there any one that sells a complete diff bolt in ready cause as you can see the only thing that looks good is the ring gear i dont want a tempoary fix looking for the permanet one
*subiepower*
PostPosted: Fri Oct 04, 2013 9:28 am
just a reminder. U can't use a cut brake if you have a solid diff.
PostPosted: Fri Oct 04, 2013 5:36 pm
just pm 091 tobin he sells German super diffs for $300 . I just bought one
PostPosted: Fri Oct 04, 2013 6:30 pm
I just bought a 091 case from him I think. Guy named Tobin from the samba.
PostPosted: Fri Oct 04, 2013 8:09 pm
he goes by the same name on both sites
PostPosted: Fri Oct 04, 2013 8:51 pm
Passat he is not welding it or putting in a spool just a good old tried and true super-diff no drink some more beer
cron
