It is currently Mon May 04, 2026 8:43 pm
 Post subject: Floaty super diff
PostPosted: Wed Oct 02, 2013 3:15 am
How do I tell the difference between a Weddle and a floaty super diff. ?
 Post subject: Re: Floaty super diff
PostPosted: Wed Oct 02, 2013 8:53 am
A floaty is what was called a beef-a-diff in the old days, it utilizes a steel block in the center that carries the secondary pins for the second set of spider gears. It is weak since the ends are not supported. A true Super diff has pins supported on both ends in the ring carrier. There is a guy on the site that can ship you a german super-diff. It will eliminate diff failures.
PostPosted: Wed Oct 02, 2013 4:54 pm
091 tobin sells the German super diffs for $300 shipped . i just bought one .
PostPosted: Wed Oct 02, 2013 8:44 pm
Thanks Just traded a 6 rib with a German super diff for one with a Weddle in it. Just wondered if I should try to get the German one back.
PostPosted: Wed Oct 02, 2013 9:43 pm
I would.
PostPosted: Wed Oct 02, 2013 11:44 pm
German parts always better imo
