It is currently Mon May 04, 2026 10:01 pm
Post new topic Reply to topic  [ 33 posts ]  Go to page 1, 2  Next
 Post subject: Blown 6 rib.
PostPosted: Sat Sep 28, 2013 9:24 pm
I launched off orgasm and landed under full power, buggy dead stopped when I landed. Winched up a few feet and trans came unlocked. Think the pinion nut blew off, it cracked my nose cone. What's your thoughts?
 Post subject: Re: Blown 6 rib.
PostPosted: Sat Sep 28, 2013 9:52 pm
new 6 rib? :D
go a head say it smart ArSs!!!
that sucks though! hope its not as bad as it sounds!!
PostPosted: Sat Sep 28, 2013 11:20 pm
That sucks. When was this ? And where is the video brad
PostPosted: Sun Sep 29, 2013 12:40 am
About 5hrs ago. Don't know what happened. Just see a crack around the outside mounting flange of the nose cone and gear oil leaking out. I let off the clutch and the shifter moves about an inch. Pretty sure the pinion nut blew off.
PostPosted: Sun Sep 29, 2013 12:41 am
PostPosted: Sun Sep 29, 2013 7:01 am
Let me make sure I have this right... You blew off your Nut while launching off Orgasm.... What are you guys doing in the woods up there :oops: :shock: :oops:
PostPosted: Sun Sep 29, 2013 7:59 am
^^^^^^^ haha well what happens at wellsville stays at wellsville wr will just leave it at that!
PostPosted: Sun Sep 29, 2013 8:01 am
Lmao
PostPosted: Sun Sep 29, 2013 9:01 am
I'd say your right the pinions busted.
Some of the best cut boggers I've seen + Hp + wild man at full throttle jumping = new tranny build. Yip sounds about right.
hpfreak wrote:
Let me make sure I have this right... You blew off your Nut On the tranny while launching off Orgasm.... What are you guys doing in the woods up there <img src="http://www.woodsbuggy.com/plugins/system/yvsmiley/phpbb/icon_redface.gif" alt="Embarrassed" class="yvSmiley"> <img src="http://www.woodsbuggy.com/plugins/system/yvsmiley/phpbb/icon_eek.gif" alt="Shocked" class="yvSmiley"> <img src="http://www.woodsbuggy.com/plugins/system/yvsmiley/phpbb/icon_redface.gif" alt="Embarrassed" class="yvSmiley">
Lmao
There fixed that quote,lmao. Chad :mrgreen:
PostPosted: Sun Sep 29, 2013 9:17 am
Hey you don't need to force people to laugh at your post chad. I was already laughing just at you instead of with you:mrgreen:
PostPosted: Sun Sep 29, 2013 10:39 am
your funny dan i was thinking the same thing
PostPosted: Sun Sep 29, 2013 12:53 pm
I bet if u had I single Carb it wouldn't have happened lol jk that sucks about ur trans.
PostPosted: Sun Sep 29, 2013 1:17 pm
Sucks about your trans brad .
PostPosted: Sun Sep 29, 2013 8:48 pm
Tranny , nut , orgasm don't mix we'll brad ! Hope ya told her you don't fool around with no Oscar Myer wiener .. Ya mush be sure that your girl is pure before the funky cold medeena . :evil:
PostPosted: Sun Sep 29, 2013 8:53 pm
Lol awesome
PostPosted: Sun Sep 29, 2013 9:01 pm
LMFAO:D
PostPosted: Sun Sep 29, 2013 9:18 pm
Should've seen him tearing shaggy up earlier in the day I still can't figure out how he does it but sure does put on a hell of a show when he climbs
PostPosted: Sun Sep 29, 2013 9:32 pm
Yeah it was a good day. Climbed m-fer, the center of pipe line, scooby, shaggy, then hit orgasm 3 times and blew a nut.
PostPosted: Sun Sep 29, 2013 9:33 pm
Lmao . Funny stuff there giveitagallan .
PostPosted: Sun Sep 29, 2013 11:54 pm
Pinion nut and or pinion bearing, plus I'd bet it got the mainshaft bearing also, hopefully your gearstack is ok.
I've done that twice, in mine it was the pinion bearing housing splitting.
PostPosted: Mon Sep 30, 2013 6:43 am
This will be the 3rd time this has happened. I have another 6 rib with everything Weddle but the r&p, wondering if I need to get an $1100 r&P?
Chromoly pinion nut with red Loctite
What needs to be done to stop the pinion nut from backing off?
PostPosted: Mon Sep 30, 2013 11:02 am
I've had good luck with weddle's wide flange pinion nut and blue locktite, it stayed on even though the pinion bearing housing split twice.
They are a pain to install, but I think they're indestructible.
PostPosted: Mon Sep 30, 2013 12:13 pm
you could try a case with a steel sleaved pinion bore.. or loose some horse power :mrgreen:
PostPosted: Mon Sep 30, 2013 6:45 pm
I meant the outer housing of the pinion bearing itself.
Threaded part of pinion bearing broke off with wide flange chromo pinion nut still attached.
I think the new weddle nuts are too brittle, not had any problems with good ole german used one installed since.
PostPosted: Mon Sep 30, 2013 9:07 pm
Krist said your have your trans fixed and hit wellsville the 18th with us ?
