It is currently Sun May 03, 2026 11:06 am
 Post subject: Rear Torsion set up
PostPosted: Thu Sep 05, 2013 3:37 pm
i am running stock boxed in arms with bus at tranny and car at wheel.
when the spring plate is relaxed what degree should i set it, and once all back together what degree should my axle be or should i say should not go over?
any help is appreciated.
 Post subject: Re: Rear Torsion set up
PostPosted: Thu Sep 05, 2013 5:09 pm
On a car cv your maxing out out around 12 degrees and 17 degrees on the bus. If you can swing the cash I'd buy a set of stubs to run bus cvs on the outer. Chad :mrgreen:
PostPosted: Thu Sep 05, 2013 5:37 pm
I'm running the same setup and as long as I'm running old car cvs I can run 20* max on my axle angle my spring plate at rest is 17* with 3x3
PostPosted: Thu Sep 05, 2013 5:41 pm
Drill you stubs out so you can run both bus n car
PostPosted: Thu Sep 05, 2013 9:41 pm
can you explain with a little more detail ? i am new to the buggy world , so i am still learning what you can and can't do.
thanks
PostPosted: Thu Sep 05, 2013 9:51 pm
its easy to drill the stubs out. First you have to cut the little lip off and then you take the bus cv and center the bolt holes in between the car bolt holes and clamp it down. Then you take a spoting punch the size of the bolt hole in the cv and spot each of the holes. Then you drill them for your tapped hole, what I do is clamp the cv back on and us the cv as a guide to make sure the tap is straight. when I get one hole taped i put a bolt in it and tighten it down. Then I tap the next hole, when im done i put a bolt in the second hole and tighten it down and then tap the rest of the holes.
PostPosted: Thu Sep 05, 2013 10:03 pm
PostPosted: Thu Sep 05, 2013 10:05 pm
PostPosted: Thu Sep 05, 2013 10:23 pm
thanks for all the info and the pictures guys. i appreciate it. :D
now i just need to get a couple bus joints. and bit and tap for that size bolt!
thanks
