It is currently Sun May 03, 2026 5:37 pm
Post new topic Reply to topic  [ 36 posts ]  Go to page Previous  1, 2
 Post subject: Re: 2332 build questions
PostPosted: Wed Jan 09, 2013 9:46 pm
I think I am stuck with at least 11:1 due to my heads being 44cc well at least with out a butt load of shims. What is the best cam with a 2387 and 11:1 my 40x35 heads(knowing that I am prob. going bigger when funds allow) and dell 45
PostPosted: Wed Jan 09, 2013 11:25 pm
My new build the heads are only 35cc, end up with a .180 barrel shim and 40 copper head gasket to get to 11.5-1 and was shootin for 10.5-1 with fk 8 But think ima just go with 11.5
"IT IS WHAT IT IS"
PostPosted: Sun Jan 13, 2013 4:55 pm
The last engine I built was 2276 with a W120 cam a single 44 IDF at 12:1 on ethanol it made 180 ft tq @ 2500rpm and 155ft tq @ 4000rpm. Keeping the heads on is the hard part but makes for a low buck woods torque monster
Travis
PostPosted: Mon Jan 14, 2013 7:13 pm
What was the compression on a stock 1600??? I'm building a 2332 and was thinking of staying around 9.5 or so
PostPosted: Tue Jan 15, 2013 12:45 pm
Mid 7's.
PostPosted: Sat Mar 02, 2013 7:47 pm
I just got my case back from the machine shop and they oversized the case spigots .010!!! Is it ok? Or do I take it back to them?
PostPosted: Sat Mar 02, 2013 11:33 pm
It will be ok. Gotta have a little room for things to expand.
PostPosted: Sun Mar 03, 2013 12:56 pm
I don't mean to ask a dumb question but with all the different CR's being talked about what is the final cranking psi. that a VW engine can be happy with? The Harley engine builders have agreed on 180-190 psi as the upper limit for 92 octane pump gas but they have anti-knock sensors and electric compression releases available for help. I just thought maybe because they are both air cooled with aluminum heads there might be similarites with detonation.
PostPosted: Thu Aug 22, 2013 7:11 pm
Update:
i purchased a set of steve timms 42x37 heads and an aluminum case
PostPosted: Thu Aug 22, 2013 8:20 pm
Most Stock 1600 was 7.3 :1 .
PostPosted: Mon Feb 03, 2014 4:49 pm
Getting her in there :)
