It is currently Mon May 04, 2026 1:13 am
PostPosted: Thu Aug 15, 2013 9:49 pm
This is my to do list and I'm going to try and have it completed this weekend !
1- pull Suby engine
2 -remove trans
3-install new trans
4 - new clutch
5- weld engine skid plate taps in
6- finish weld everything that is tacked in engine bay
7 - finish weld exhaust
8- finish weld coolant tubes
9 - cut and install skid plate
10 - remove ps pump and ac pump and install a bypass belt for alt
11 - install engine
12- put coolant in :twisted:
13 - put cv together
14 - pull wheel hubs and install 5/8 studs
15- put cv and axles in
16 - adjust limit straps
17 - make battery hold down
18 - run throttle cable setup
19 - run clutch line to slave cylinder and bleed
20- bolts seats and harnesses in
21- adjust shifter
22- finish bolting floor down
23- finish bolting sides down
24- fix steering shaft
25- weld all thread in front beam and double nut
26 - tighten all bolts on front end
27- put spacers in rear coil overs
28- finish wire rear lights
29- to be continued
I think I can ..... I think I can lol
PostPosted: Thu Aug 15, 2013 9:52 pm
Well at least someone's list is longer than mine lol
Good luck hope to see it in trails soon!
PostPosted: Thu Aug 15, 2013 9:53 pm
Holy shit. I thought I had it bad. I have to put oil in my shock and fill it with nitrogen.
PostPosted: Thu Aug 15, 2013 11:41 pm
Trust me, I know the drill. Just mine running again tonite, a week in advance, not an hour in advance.
Can't you leave the a/c pump on, they're a great start for onboard air. I converted the one on my white XJ simple as oh heck and really handy on the trail.
PostPosted: Thu Aug 15, 2013 11:59 pm
OK.. You win...I think I have to charge my battery (kids left the lights on) and dry my seat...
PostPosted: Fri Aug 16, 2013 12:05 am
Gig with your track record for this build . I hope you got a second string!!!!! :shock: 8) :mrgreen:
PostPosted: Fri Aug 16, 2013 12:53 pm
Second string = Customer's John Deere riding lawn mower from the shop, without anti freeze of course.
PostPosted: Fri Aug 16, 2013 1:04 pm
Yer fast. I do more work all day than most people get done by 8:30 am. lol
PostPosted: Sun Aug 18, 2013 7:53 am
Lol , you guys got me . I ended up getting sick Friday and I'm still laying in bed ! :(
PostPosted: Sun Aug 18, 2013 1:43 pm
Damn Jason, I was gonna call you this morning to see if you needed a hand but if your just laying in bed that would be kind of gay so im not coming over :P :P
PostPosted: Sun Aug 18, 2013 3:48 pm
Want us to drop off some Midol and a warm compress?
PostPosted: Mon Aug 19, 2013 10:07 pm
MEOW
This one time at wellsville
