It is currently Sun May 03, 2026 11:13 am
 Post subject: 2275
PostPosted: Sat Aug 10, 2013 6:00 am
What scat cam and what set of carbs would be a good choice for this engine? The engine kit im looking at is this one from scat... 2275 SCAT VOLKSTROKER VOLKSRACER RACE-READY ENGINE KITS
This kit is race-ready and engineered for increased horsepower and pre-clearanced for longer strokes
◾Nitrided chromoly forged crankshaft
◾NEW SCAT forged H-Beam rods (Chevy or VW journal)
◾NEW Stroker AS41 dual by-pass engine case
◾NEW 'D Port' polished dual-port heads
◾NEW 3/8" cut to length chromoly pushrods
◾NEW Crankshaft Gear Assembly Kit #10207
◾NEW 40-piece Engine Lock Nut Kit #10173
◾NEW Universal Engine Case Hardware Kit # 10205
◾NEW SCAT adjustable O-Ring aluminum pushrod tubes
◾NEW 4140 chromoly 8mm dual-port cylinder/head stud kit
 Post subject: Re: 2275
PostPosted: Tue Aug 13, 2013 2:47 am
Anyone?
PostPosted: Tue Aug 13, 2013 3:17 am
carbs either dual webber 40s or 44s dont know about cam
PostPosted: Tue Aug 13, 2013 4:31 pm
Running a c35 in my 1915 and love it.
PostPosted: Tue Aug 13, 2013 4:33 pm
If I was to run a scat cam it would be a C35. Jmo. Chad :mrgreen:
PostPosted: Tue Aug 13, 2013 5:33 pm
That's what I'm putting together rite now. 1915 c35 cam and dual weber 44s. Some day I plan to swap a 82mm crank. Just wanted to see if you could run the. c35 cam in a 2275. Seems like it would be kind of small but paired with the rite heads and carbs it should scream. Thanks for the feed back. :)
PostPosted: Wed Aug 14, 2013 11:37 am
i run a fk43 engle. 1:4 rockers. single 44 weber. runs pretty good, seems to make good power.
