It is currently Mon May 04, 2026 8:03 am
Post new topic Reply to topic  [ 525 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6 ... 21  Next
PostPosted: Sun Aug 11, 2013 11:25 pm
Quote:
Walked by my single seater and flipped it off and said a few choice words,lol. Chad :mrgreen:
Now what did the buggy do to you lol :mrgreen:
Finally went for a ride:) then got caught in the rain:( just my luck lol
PostPosted: Sun Aug 11, 2013 11:46 pm
Pulled motor off 2 seater to put on 4 seater to get ready for rush on the 24th hope to have it ready... :)
"I got this..."
PostPosted: Mon Aug 12, 2013 1:22 am
Looked at it sitting there out of go go juice. Been helping my neighbor with his derby cars for next weeks races at the fair. Running 3 cars should be a blast.
PostPosted: Mon Aug 12, 2013 10:07 am
I finally done something, got it out of storage and into the garage...used the thing one time this year :cry:
PostPosted: Mon Aug 12, 2013 11:05 pm
Not so much what I did to the buggy but picked up a truck camper to have a place to sleep when I finally do get it out and go ride,lol. Chad :mrgreen:
PostPosted: Tue Aug 13, 2013 12:12 am
Looked at being all muddy from yesterday. To lazy to wash it :mrgreen:
Sent from my iPhone :mrgreen:
PostPosted: Tue Aug 13, 2013 12:13 am
Put gas in it finally got it started after running it empty. Loaded it up in the back of the trailer. Rained cats and dogs just after I got it loaded.
Hope to ride soon.
Flipper
PostPosted: Tue Aug 13, 2013 9:15 am
I finally made progress on mines. The 2 seater is running although I still need to make some adjustment on the clutch cable. Also having problems bleeding the brakes, it brakes fine with the cutting brakes but it doesn't brake via the pedals (although it does build some pressure in the lines when pedal applied its not enough to engage the wheel cylinders). The 4 seater is also running after swapping a head. No more popping. I will setup the clutch cable also on this one tonight and finish raising the other front spindle and hook up the front disk brakes (hopefully). The 4 seater also need hooking up of the tractor brakes and park brake but there ain't enough beer in the world to accomplish this in one night by one person.
PostPosted: Wed Aug 14, 2013 10:49 pm
I replaced my bigger winch with an even bigger one. Thank goodness I don't have any more bigger winch's...lol
PostPosted: Thu Aug 15, 2013 10:38 pm
I added a bar to my head/pushrod protectors that would keep it from bending upward.
PostPosted: Fri Aug 16, 2013 8:28 am
Pulled my motor down far enough to find slop in the rod bearings. Then cussed for several hours while I drank to much beer for a Thursday night.
PostPosted: Fri Aug 16, 2013 10:13 am
gasman wrote:
Andrew_Ha wrote:
Cutting tire mounting new lights bought 30" led light bar
Oh man will you love the light bar, they are the shit.
Now that is a true old school buggy owners response :grin::grin::grin::grin:
PostPosted: Fri Aug 16, 2013 3:25 pm
Burnt in the torsion welding some other bars up Still workin on er now:mrgreen:
PostPosted: Fri Aug 16, 2013 3:52 pm
loaded it on the trailer cuz im bout to beat that bitch a little!
PostPosted: Fri Aug 16, 2013 11:35 pm
installed remote oil filter setup and changed oil. oh probably pissed off a few neighbors by revving the engine up? Just a few times? :twisted: hey i had to check for oil leaks!!! LOL!!! :twisted:
PostPosted: Fri Aug 16, 2013 11:54 pm
Big d I think you need a bigger winch still if I ride with you at Black mountain.
PostPosted: Sat Aug 17, 2013 2:02 am
7 out of10 times I'm stuck it requires a chainsaw not a Winch either i flip off a hill and roll up on a tree or I rolled back and my front end caught a tree im tailing you a tree is
a buggys worst friend When in doubt
Stomp it and hold you will make it to the
Top or roll back to the bottom either way
You will have a ball or two
PostPosted: Sat Aug 17, 2013 3:19 am
Well motor went out on me so went and bought my pistons and cylinders and total seal rings and gasket kit and stuff and had joe bore the block so rdy to build come monday once I change oit bearings for right size hope to be in woods for laborday
PostPosted: Sat Aug 17, 2013 9:40 am
Na.. Eric...Black Mountain isn't that tight. You won't get stuck..maybe drop in a hole...lol
PostPosted: Sat Aug 17, 2013 9:43 am
I know what you mean jeff69. I had to cut one tree down after whinching..lol
PostPosted: Sat Aug 17, 2013 1:15 pm
changed the oil and filter , replaced cv boot and replaced a oil cooler line . I have a growling 3 rib but I am going to run it till it breaks .
On my wife's I swapped the rear v treads for some buck shots , changed the oil and filter , changed the idle jets to 55's , set the timing , adj the valves ,killed about ten spiders in it where its been sitting . After lunch I am going to try to get the right side brake to do right .
PostPosted: Sat Aug 17, 2013 7:29 pm
It has been a really busy day with the buggy.. I re-installed the NOS tank with two bolts and touched up some paint on the tree bars. I am worn out. :lol:
PostPosted: Sat Aug 17, 2013 9:10 pm
Didn't touch the buggy today went to a wedding. Now partying it up at the reception!! :mrgreen: needed a break from the buggy :lol:
PostPosted: Sun Aug 18, 2013 11:08 am
Installed new shifter, limiting straps, and a new set of gateways. Cutting tomorrow
PostPosted: Sun Aug 18, 2013 5:36 pm
Unloaded the buggy out of the trailer. Took everything out of said trailer, then swept it out. Got barefooted and shook the hell out of the gallon paint can. Poured it out in the roller pan and got to painting the inside of the trailer. WHITE!!!!! Really brightens up the trailer so at night it will be bright enough to see if I have to work on the buggy out at the camp sites or at a buggy ride.
Debating on what to do to the floor, either LineX or buy the rhino and do it myself. That or diamond plate the floor!
